Hello,
My 68 is going through a v6--v8 (and automatic transmission) conversion currently. I went to see it and the new v8 engine appears to be mounted at a slight angle - higher in the front than in the back. The mechanic said that it was done like that in order to avoid cutting into the frame/body. I've attached a picture although it's hard to see the angle.
Is this normal/expected?
