msommer001
- Jan 15, 2009
- 377
Can the vacuum advance for the distributor run into the back on the EGR? This is how it was when I purchased the Bronco, I am hear that, this is not correct. There is another vacuum port on the carburetor that I could connect it to once I confirm that vacuum is only created when I mash the gas.
Correct, I need to make sure that there is no vacuum at idle correct?
I have looked at the vacuum diagrams and they do not match what I have, I will post some photos tonight, but it does not appear that there is a "Cooling PVS"
It would be very helpful if anyone has a 77 diagram they can share. Is the 77 different or should a 76 or 75 diagram be the same?
Thanks in advance.
Thanks in advance.
