Valve cover options for 302 with EFI Manifold 5.0
fordguy
I have a set of those Ford racing covers that look just like that and clear the Mustang intake manifolds, and I have roller rockers.
are you able to run the baffle over the filler tube? i have the mustang ones like viper polished but they dont clear roller rockers with the baffle installed
boonz28
I have 1.6 ratio pedestal mounted roller rockers and made no modifications to the valve covers. Everything cleared just fine out of the box. I did need longer bolts for the covers as well as a spacer between the upper and lower intake but apparently thats only a problem if you're using the explorer manifold.
fordguy
yeah i aint that lucky, the nut hits the baffle on one set. the other set clear but is has no baffle, which probably will allow it to suck oil through the tube on the filler neck.
fordguy
problem solved, pulled the valvetrain and cam and went back stock. did not want to pay 200 dollars plus for spacers. stock works great.
fordguy
Kyle, if I was running a carb, it would have only taken one set of spacers. The type rocker I had (pedestal mount comp cam) made it where the nut sit really high. Any solution I would try would cost more money. As luck would have it, the number 7 rod bearing cap got crossed up with the number 1 and it caused a seizure of the rod (not while running but while turning it over). So we had to go back in anyhow and it is cost me nothing, already had the stock cam.
73azbronco
=The old how do you know a mustang has 1.7 vs 1.6 roller rockers? The bump in the hood for the taller valve covers, intake spacer, etc.
My bigger problem was driver side rear valve cover hitting firewall and i have a 5.0 with 2 inch BL but using Edelbrock heads which are slightly taller.
This would not fit and hit the firewall:
https://jet.com/product/detail/adf1...L48c_zM34kpguXEuopVTA1PSgknVJfBxoC8HkQAvD_BwE
This would fit, note canted part of valve cover allowing closer fit to firewall but still allows large 1.7 to run free with no baffle issue:
https://www.summitracing.com/parts/pro-302-003/overview/make/ford
Unfortunately i think it warns not for use with efi, unless spacer used, sorry
KyleQ
Crap - I meant to post a picture of those covers clearing with the GT40 intake setup... sorry to hear about the motor, glad you figured that out before starting it.
Miles of room with the Typhoon intakes-
GT40 clears fine too - although the most expensive setup out there.
