Vin decoding bronco
LagottoATL
Atlanta, Georgia
little help/confirmation:
VIN off the frame: *U15NLB03756*
My engine casting number: C60ES430-F
Looking to sell this uncut survivor. But wanted to fully understand before I did. I believe (and was told 10 years ago when I bought it from a guy who inherited from his uncle) it is a ‘67. VIN checks out. N (289, which is consistent with the emblem on the truck) which means it had to be 66-69. But the last 6 digits (B03756) is not listed in the ‘67 series (which all start with an “A”, not a B). The only “B” number I could find comes from the 76 series of productions. Any thoughts on year?
Also, the engine casting suggests the engine is a ‘66 (which is consistent). However, the third digit is a zero which apparently is not common (should be a letter). My best guess is the engine is a ‘66 ford, 289. But what is not clear is that it seems to be made for a mustang or fairlane. Does this make sense? Is it possible the engine was replaced by prior owner? It has the patena of an original engine.
Given early year, is it possible Ford interchanged engines among models?
Long time listener/reader, first time (maybe 3rd time) caller. I’ll hang up and listen…
Thanks in advance
okie4570
NW OK
289 was an option in 66' models starting in 3/66' and continued through 7/68'. They didn't extend into the 69' model. B03 is a March 67' build. If you're looking at Broncohio, that's all messed up on the 67' vins.
I'm no help on the casting numbers on the engine.
L
LagottoATL
Atlanta, Georgia
Awesome! Thanks. And yes, Broncohio was where I was looking. And very cool to know she's a March '67 build.
toddz69
Here's a Ford document from a TSB that can be very helpful with accurately determining the VIN info for the 67-69 years.
Todd Z.
And the “engineering number” (not necessarily a specific part number in this case) on the engine does not automatically mean that was the year it made or installed. Just the year it was designed.
For the year and month and week it was made you would actually have to look at the casting date numbers.
They could’ve used a “C6” designation all the way through 68 if they didn’t make any major changes.
If they had made changes, they would have changed it to a “C7”, or a “C8” instead.
jamesroney
Fremont, CA
Todd Z.
You know I trust you...but the TSB reference doc and BroncOhio are killing me...
My Boxwood Green 1969 Bronco is VIN F78448. Kevin Marti, and all of the native date codes are June of 1969. and yet???
  • Marti_report.pdf
jamesroney
Fremont, CA
Thanks in advance
Is your engine casting number located on the passenger exhaust manifold? Could it actually be C6OE-9430-F
The C6OE-9430-F is consistent with the 1966 Ford Intermediate Passenger car exhaust manifold used on the 66-70 Bronco.
The engine casting number is located above the starter near the oil pan, and should have a -6015 as the root number. Most likely C5AE-6015-E, or else C6AE-6015-C Both used in 289's up to 68. I think it's too early to be a C8OE-6015-B, although many late 67 Bronco's got the 289 with the 68 cast 302 block.
toddz69
Hmmmm.....that's very interesting. I seem to recall another late '69 VIN deal like this recently - I think it was a truck on BaT? Obviously the Ford data I quoted was incorrect because you have a truck with that number on it...I think I found another source with the higher numbers in it somewhere but I can't recall where it was.
Todd Z.
toddz69
@jamesroney - I found the other document I was thinking of in the Master Parts Catalog - it lists the production #'s as follows so your truck definitely fits within the numbering scheme for the year.
Todd Z.
L
LagottoATL
Atlanta, Georgia
You guys rock. The number I pulled came from passenger side manifold. I’ll try and find the other number as suggested and post. It seems everything is lining up to what I initially thought. A true ‘67. For a moment this weekend, I thought I had a ‘76. Nothing wrong with that, may be better—who knows—but I love my old gal just as she is. Hope next caretaker appreciates her as I do!! Thanks again all.
