VIN Issue?
blaked21
Unfortunately someone hit my 1972 bronco while parked in a garage and didn't leave a note. The damage is bad enough where I'll need to get my passenger door and front panel repainted. As I've brought the Bronco to a few shops to get estimates. they've asked for the VIN and I realized the only way I know it is from the title.
I need to clean the frame off, which will pose its own challenge due to space being extremely tight with a 351 and some trans cooling lines in the way but thats another story.
I was looking at the VIN on my title and see it is U25, which doesn't appear to be correct. I've had the vehicle registered and insured using the U25 VIN for several years but am wondering if this could be a can of worms if I ever got into an accident or tried selling the vehicle.
Am i correct in that no early Broncos started with U25 and what headaches should i anticipate with this issue?
okie4570
NW OK
Correct, that digit where the 2 is, should be a 1 on all models and years.
crawln68
I have corrected a VIN number issue just like yours (one digit off) with a simple form at the DMV. I don't remember, but they may have done a VIN inspection to verify the correct number too. But it was pretty easy process.
B
blaked21
Thanks for the input. I'm in Illinois and have had the vehicle registered/insured for 3 years with no issues. I am a little worried that there could be other discrepancies with the VIN but we'll cross that bridge when i have some time to look at the frame.
WheelHorse
So the body shop will not honor the warranty tag vs the door tag?
IF the frame vin was so important, why the hell did Ford bury it under the passenger seat on top of the frame where it's a nightmare to attempt to read with a mirror: at least on my '77.
I know other models have it straight down the firewall, but even then, maybe this is another one of Ford's ridiculously silly ideas...I'm stating this as nicely and professionally possible. If the VIN is a dog gone sticker on the door pillar and that's acceptable (a sticker) but not a stamped glove box lid because that's a warranty tag, sometimes I really wonder Ford's logic.
AZ73
The only VIN that matters is on the frame. The door sticker is to make it easier to read but since you can peel that sticker off, or paint over it, or even make a fake one, it's just for convenience. If you look at most cars, even back in the 60's, the VIN is just inside the windshield on top of the cowl (surrounded by the dash) were it's protected and difficult to change unless you pull the windshield. Can't put it there on our early Broncos so it's on the frame.
Rangerbj
The frame vin is not difficult to find. Just takes some time in cleaning surface. I found best to clean it with wire brush the use your phone to take a picture of it. With the phone picture you can zoom in close to read it. You know it is on passenger frame rail on top, just down slope from the front shock. Look for the three holes. Two circular holes with an elliptical hole between them . About 3-5 inches down toward passenger floor board.
Also, Ford had plenty of mis-stamped vins. Yours would not be the first.
Crawdad
I’ve personally been down this rabbit hole. I was unfamiliar with VINs until I sold my 76 (which originally belonged to my dad). I found the VIN buried on the frame (topside)on the passenger side where the motor block meets the bell housing. I had a two inch body lift so that made getting a small brush and wire wheel that much easier. You may encounter layers of grime and mud. If it’s rusty I’ve found muriatic acid and a small wire brush helps big time (wear PPE). Once you find it spray paint it. If it’s too tight to see VIN lay a piece of paper over the area and take a pencil/crayon/ whatever it takes that you can press down over the area side to side. After I found my VIN I noticed the stamped VIN on the frame was one letter off. Because of that I lost out on a sale. It raised a red flag with the potential buyer. I few days later I went to my DMV and they did a research on it and found out they made a mistake 25 years ago. It was a simple fix on their part and I got a new title. Nonetheless I still lost out on a sale. Two weeks later I sold the 76 with a Title that visually matched the VIN stamped on the frame.
Now...... if the stamp on your frame doesn’t match your title then you got had. Someone switched out the frame for a better one in the past. Could have been swapped in 1977, 1984 or 2010. Who knows unless you purchased from the dealer yourself. Early Broncos are legos that can be easily interchanged back and forth. Some states go by the warrantee tag on the glovebox. But some states (like SC) will want to visually see the stamped VIN if it’s coming from out of state. If the see that the frame vin doesn’t match the title that can lead to another can of worms. They will first check to see if it’s stolen! If it is expect a huge headache and a lot of time without your bronco. You would be lucky to get it back in a few months. I will not give any advice to you if it doesn’t match your title at all.
I got dupped into buying a 72 (see my 77 build). The PO told me the glove box tag, frame and title was all “clean”. I only checked the glovebox and not the frame. Yeas later i find out frame doesn’t match and the PO refuses to return my emails. It was a lesson learned and a mistake I won’t make again. I didn’t want to take the chances of showing it to my DMV I searched out a good frame with a clean title. I found one from MikeD and I went straight to my DMV. After they inspected my bare frame I was able to get the registration in my name with a new title in my hand a few days later. The rest is history and again can be found in my 77 build.
I only tell you all this bc one day I may sell my 77 or my wife/ children may have to sell it if I’m gone from this world. The transfer of my bronco to someone else will be easy. One thing is for sure the next buyer would have absolutely no problem registering it in any state as long as the stamped VIN remains intact.
Matt
Jon67sport
Boozy Creek, VA
I have a similar issue on my Bronco that I have owned for over 30 years. The VIN on the title and registration starts out as US1 instead of U15. It is a typo made by the DMV 30+ years ago. I was at my local DMV last week on another matter and I showed them my registration and a photo of the VIN on the Bronco that I had taken that morning and asked them what to do about it. They told me it was easy to fix. I could bring the Bronco to them and someone would verify the correct VIN and make it right on the title. They also said that if the Bronco could not be driven, I could call the local law enforcement and have one of them come out to verify it and the officer could sign off on the form which would be all the DMV needed to correct the title.
svastano
Pulaski, PA
I only wish I knew then what I know now about VIN #'s SO much great info on this board! My 77 has the original frame at least to my knowledge. But back in the day we had the whole thing sandblasted and hot dipped galvanized so the likelihood of the VIN numbers still being there are nil and none. I only have the "sticker" and the glove box number and a PA title that matches. I hope that this never becomes an issue in the future for my kids!
Crawdad
Muriatic acid will remove paint and galvanized coating. It’s very caustic and must be handled carefully. I’d start out with diluting a bit. But it will work along with some elbow grease. I too had my frame galvanized. In fact I had it done twice and then had it powder coated. Each time I made sure go protect both stamps on my frame (the silver rectangles).
B
blaked21
Quick update. I didnt sleep well last night imagining the worse case scenario and the VIN on the frame not matching and being up sh*t creek. It took some time and a lot of wiggling and trying to look at every angle possible but i was able to get a look at the VIN. I'm 99% positive it matches the VIN on my title, except for the typo of U25. I say 99% because i can clearly see the last 5 digits and can mostly make out the rest except for the U. Its extremely challenging not only because of grime and dirt buildup but also the transmission cooler lines run right on top of the frame covering a good chunk of the VIN and offer little to no flex.
For me seeing what I can see clearly is good enough to calm me down but I'm not sure someone at the DMV or law enforcement would sign off on it without a better look. I have to get a new license in the next month, so will ask some questions at the DMV and will spend some more time cleaning the area and trying to move the trans cooler lines that are causing the issue.
Thanks for the insight and helping narrow my search on the frame.
chrlsful
complaints abt them being tucked away: I think that is due to the national idea abt stolen vehicles @ the time. No 1 thought abt 'classics' & yrs dwn the rd. A piece could B IDed at a chop shop, or police could have the info abt where to look on a vehicle to ID ownership.Thieves just grab'n go.
Each state is different, find ur local DMV ordnances B4 worry. After "getting the deal" U can worry, but really? no worry then too as they have work-a-round strategies - just like mechanics...
