The only thing I can find on an 18 code is a 3.50 rear end, usually a 2780#. The only thing I find on a "J" is for the front axle, and means a 2500# axle with limited slip. This is weird though because I can't see them putting a LS axle up front when there isn't one in the back. The only limited slip rear ends have a "alpha" character in front of the axle code... (ie. A5J)... The all numeric code for the rear axle means it is an open dif from the factory, without exception. That doesn't mean someone didn't put something in there after market. I have just seen an explanation that states the "J" could also mean you have power steering (Do you??). The U153 is the GVW rating, it is one of the middle ones, the U152 is the heaviest... I am guessing the U153 indicates the same 2780 axle... I don't know what the body code is, but I think by 1975 they were only making a wagon, so it may refer to it being a sport or ranger... something like that??
Hope this helps a little...
Dave
