jpopsbronco
If your a junkyard junkie looking for power door locks, grab the power door locks out of the taurus, while your grabbing the fan
. You want the ones from the rear doors. when removing them cut the wires then use a flathead screwdriver to bend the platic mounting tab off it and itll pop right off. then bend the metal shaft and wiggle it outta the whole. on our broncos they have an extra hole on the key operated side of the locking mechanism that works perfectly. I just siliconed mine to the door skin at the bottom and bent the metal shaft to make it line up with the hole. Its fits in there perfectly and clears the window. I had an alarm system that had power door lock controllers so thats what i used. It looks like you could use the power door lock upgrade kit from bc broncos to control them too. Its a fair amount of work but for me it was worth it. if anyone wants pictures pm me your email!
http://www.bcbroncos.com/interiorupgrades.html
