Wanted- 302 fuel pump, no junk allowed
johnbeck
I installed a new 6962 fuel pump. It has 3/8 inlet. Unfortunately the discharge female fitting isn't threaded all the way and a screw in flange fitting with a 3/8th's nipple won't seat. It leaked gas when I was trying to break in the engine. I swapped the adapter 3/8ths fitting into my old pump - no leak. I bought another identical brass fitting - it leaked on the new 6962, not on my five or six year old pump. Who sells a 302's mechanical pump with 3/8ths fittings that isn't junk? Just to finish the engine break in I'm thinking of just using my six year old pump - any idea how long a fuel pump with minimal use should last? Thanks, John B
No, there's no way to tell. But if you're breaking in an engine, use whatever you've got that is known to work.
There is one consistency with pumps it seems, and that is that when they were lightly used, then put away for a couple of years or more, they regularly fail within a short time.
That said, yours is still working, so use it at least for now. You either got lucky and got a great pump, in which case you'll be happy with it for a long time, or you'll be like most and it will fail in short order.
But in the meantime, either way you win by having a pump that works. Even if just for now...
Rustytruck
For many years I use to use Carter fuel pumps and then they started failing prematurely the last 2 carters I bought only lasted a couple of years. I took the last one apart and the check valve seals were swollen and not sealing. the diaphragm was fine. so I started looking for another brand. I found Airtex branded mechanical pump. this pump is working fine now for 3 years now. The California special gas is a problem here.
https://airtexasc.com/product-details?partkey=000566189
Pops68
Bronco Rookie
Bazetta Township
Is it possible to get the proper size/thread tap and extend the threads deeper to where the fitting will attach better and not leak??
Not sure if this is possible or not......just a thought???
Pops
Rustytruck
Ford used 5/16 fuel line on the 302 engines. you could use a barbed 3/8 line connector and slip it over the 5/16 steel line and solder or silver solder it together.
either that or use a line adapter at the fuel pump and run all steel fuel line from the pump to the carb, for fire safety your best to run all steel line from the pump to the carb since the line is under pressure. summit carries a braided fire sleeve you can put over the steel line to help insulate it from heat. You want to put that on before you cut, put on the tube nut and flair the line.
J
johnbeck
Once again thanks so much for all your help. Pops, threading deeper would possibly work if the metal on this cheap pump wasn't so thin. The pump is an Airtex 6962. Unless I discover a quality pump I'll just throw the six year old pump in to get the Bronco running. Thanks for the suggestions, John B
AC932
So far I've had good luck with the NAPA replacement fuel pumps. Not quite OE quality, but they work and the fittings are the right size
mhinchliffe
I got 300 miles out of my first NAPA pump. Qualifier is that I had to replace the ancient one and I'm thinking maybe it failed due to wear caused by residual debris after tank flushing/installation, same with plastic OE fuel line.
Also will add that I replaced with NAPA warranty unit.....still pumpin'
J
johnbeck
What NAPA 302 fuel pump number did you use? I need a 3/8ths inlet. Thanks, John B
EPB72
Pleasant Hill, CA
john lately alot of fuel pump inverted flare fitting don't seal when first tighten .one trick is to tighten and loosen the fittings 3 or 4 times and tighten a little tighter each time ,,this kind of reforms the seat of the fittings.
tirewater
San Francisco Bay Area
What fitting are you screwing into the fuel pump? The nipple adapters I'm seeing online are pieces of metal fuel line with the flare and screw fitting attached.
The other possibility is that the adapter you're using may not be made for the flare in the fuel pump, but you were lucky with your older pump one.
EPB72
Pleasant Hill, CA
https://www.discounthydraulichose.c...3/8" Hose Barb x 5/16" Inverted Flare | $2.68
From the OP I'm assuming he's using something like this fitting to take place of the original 5/16 steel line that went directly into the fuel pump..
Rustytruck
my understanding is he needs 3/8 hose going into the pump and 3/8 hose going out to the carb. stock bronco pump is 5/16 hose fitting going in and 5/16 tube nut going out to the carb.
can use a 5/6 tube nut to 3/8 hose going out but still has a problem on the input side.
That is if I am reading and understanding his posts correctly.
Rustytruck
my guess to end the frustration he will have to use a Holley or Edelbrock aftermarket fuel pump as they have threaded ports going in and out. but at 3 times the price.
RonJones
I’m thinking those pumps are $140 or so, put out 10 psi and require a pressure regulator to get them down to 2.5 psi for a carb.
https://www.amazon.com/dp/B000CN4ZWY/ref=nav_timeline_asin?_encoding=UTF8&psc=1
Running 5/16” inverted flare fitting and steel tube from the pump up to the vicinity of the carb, place an AN-5 to AN-6 union adapter, and couple that to an AN-6 filter and send that to the carb with 3/8” tube sounds like a better idea to me.
J
johnbeck
I have a 6962 Airtex fuel pump with a 3/8ths barbed nipple for inlet and a stock female discharge designed to accommodate a 5/16 steelline with a flared male fitting. The inlet has 3/8ths rubber fuel line clamped to the nipple. With the discharge female I tried to screw in a brass fitting with a 3/8 barbed nipple to attach a rubber hose to my Edelbrock carburetor's 3/8ths inlet nipple. Unfortunately the fitting leaked at the two mating flare surfaces. I spent so much time trying to make that discharge fitting not leak. For now I'm going to attach a section of 5/16ths fuel line with a flare nut and flange, attach a 5/16" to 3/8" adapter with hose barb, attach the 3/8ths rubber hose to the carburetor. I wished the discharge screwed in 3/8ths nipple hadn't leaked, it would have been so easy. I did look at the pricey $140 pumps but then you have to add a fuel pressure regulator - too much time to spend right now. Thanks so much for your help - the encouragement is getting me closer to the finish line. John B
gr8scott
That pump is the racing version. The Edelbrock 1725 is the street version which puts out 6 psi, perfect for a AFB/Edelbrock/Carter four barrel.
Been running mine for a long time, no regulator, no issues.
https://www.summitracing.com/parts/edl-1725
Nobody's going to like my recommendation, but I've used it for literally decades on several vehicles and never an issue. Use the stock size outlet tubing and use one of the clear universal filters near the carb.
The "newer" versions of the filter (most from about the mid-'80's or so) with the plastic thread-in barbed fittings allows you to use a 5/16" inlet fitting and a 3/8" outlet fitting. Run your metal line up to the filter in 5/16, then use 3/8" from the filter to the carb. Done.
Ever since they replace the glass enclosure with polycarbonate material I've never heard of a failure other than related second or third hand. Maybe it can happen, but I don't see how it can break under anything resembling normal circumstances.
Still, I take a length of heater hose and slice it lengthwise and wrap it around the filter to protect it from banging on the metal engine parts and from being hit by a tool thrown around in frustration or whatever.
As long as you have tightened it sufficiently it will not leak any more than any other type of fitting. At least none of mine ever have and I've been using that type of filter since the late sixties.
As for the pump having a 3/8" inlet, I've never had to deal with that before because by the time I had one of those I also had an aftermarket fuel tank that used 3/8" fittings anyway.
