Warn hub assembly help
pcf_mark
I have my Dana 30 from my '68 all apart. I was cleaning all the parts when I discovered that the left and right locking hubs do not have the same pieces. I took one side apart, then the other so nothing is mixed up. Does anyone have a diagram of how these go back together properly. Also a source for individual replacement parts? Warn only seems to sell the screws!
What I noticed so far: One side has a hefty spring and a smaller spring. The smaller spring is still large in size but very small gage so it does not have a lot of force. This was on the outside of the assembly farthest from the axle. The other side does not have this lighter spring but has the big spring. On one side the big spring has a spring seat the other does not. One side has a bronze thrust washer about .060 thick the other side does not. Wacky! I would like to get these installed correctly. I am wondering if these things are in a yard I could scavenge?
Any chance you can post up some pics pcf? Are you sure they're both Warn? Other than the springs, do they look the same?
NONE of the aftermarket hubs use that large inner spring. The diagrams in Steve83's link are for original stock hubs.
A Warn (and all the other aftermarket ones I know of) are usually removed and installed in 2 major pieces. An inner assembly with the aluminum splined slug and internal parts, and the outer knob assembly. The stock ones would come apart in individual pieces like in Steve's diagram.
The inner assembly can come apart though, by just removing one screw that retains the sliding splined inner collar. Sounds like the one with the very lightweight spring is just that. A Warn with the inner parts dis-assembled.
If it turns out they're both Warn hubs, do NOT re-install that large spring with the seat.
Sounds like you've got a mix of parts though, so make sure first.
Anyone have any suggestions?
Yeah. Leave the big spring out! If it looks like the one in Steve's pic, it's part of the original Spicer type hub, and has no business in there with an aftermarket hub.
What does the backside of the aluminum assembly look like? Got any grooves worn in it? If not, that's a good sign.
But take it out anyway. No sense in living dangerously.
pcf_mark
pcf_mark
Still no photos sorry.
It does not look like DirtDonk's photo exactly. Conceptually yes. My cap, item 5, has six screws but they are flush with the top surface where the knob is. I do not have the gasket, item 12, because my cap has an o-ring on it.
Also the main body, item 13, is ribbed on the outside also. All the parts within item 13 in the photo stay together. Then I have the cap assembly with a large low tension spring between them on one side only. Then after item 13 I have a large spring on both sides. I need to find some photos that are closer to the version I have. Craptastic!
Thanks for your help!
