Hey Guys,
I think this has been mentioned before, now that I searched for it, but I was unaware... DONT USE THE ORANGE RADIATOR FLUID IF YOU HAVE A COPPER RADIATOR!
I recently decided to change out my cam from the FMS E303 to Crane Cam 444211, so that involves removing the radiator & etc. When I was taking out the radiator, I noticed a little leakage, ok no problem, but once I got it out I noticed the whole thing was trashed. Most of the fins along the bottom are that blue-green color and basically just wipe away; they disintegrated.
I bought this radiator (4 core) new from James Duff around the year 2000. I was running the green stuff, but a few years ago I switched to the orange stuff because it is supposed to last longer. Mind you, I have only put maybe 3000 miles on the engine in that past few years, so forget the 150k mileage they say it should work...
So, when I saw this corrosion, I poked around on the net, and I found some sites that say not to use the orange stuff with copper (and some plastics, as you see there is problems with GM's Dexcool)
http://www.popularmechanics.com/automotive/sub_care_sat/1272436.html
http://www.consumeraffairs.com/news04/2006/08/gm_dexcool.html
They say it messes with the lead in the system, but I think there is something with the copper as well because copper is relatively corrosion resistant.
BTW - looks like you want something borate free when you are using aluminum, such as in an intake manifold. However, make sure that it has phosphates to protect the aluminum.
Anyway, looks like I'll be shopping around for a new radiator. And I'll be going back to the green stuff, I don't care if the neighbor's cat wants to drink it...
If anybody wants to see pictures, let me know, I can probably snap a few.
