00gyrhed
- Aug 3, 2006
- 2,428
guys think of it this way. you take water and separate it. where does the engergy come from. electricity. You have to generate electricity by running your engine. It is the basically a perpetual motion scam.
split water into oxygen and hydrogen in the exact ratio it combines to form water. pipe the exhaust to the ball glass jar so you do not have to add water. now where does all this energy come from to drive the car. It takes more energy to split water into H2 and O2 than you get back when you burn it. There is research into catalyst that have shown to lower the threshold but the key to making it work is $. you have to have a cheaper scource of electricity to split the water molecule than the fuel costs to run the vehicle. Your alternator is not a cheaper scource.
If this guy has the answer why does he run a hybrid that needs gasoline??
Unique electrolisis process?? What you need is a real live chemical engineering thermodynamics phd to look at this guys claims. If his claims were true he would be a millionare right now and would be selling these hoaky little kits. Come on. Auto manufacturers would have scooped it up. Heck the oil companies would pay him billions just to go away, but no you can buy a kit with a Ball canning jar on the internet for just a few dollars. The cost isn't even in line with the claimed savings. Pays back overnight.
The energy to split the water has to come from some where, and you don't get it back when you burn it in an engine. An engine is like a 75% waste. Energy leaves the ssytem through the radiator, exhaust, radiates from the block in addition to friction lossses goin to the rear wheels.
Also this gas mixture of HHO is extremely explosive. UV light will set it off.
Basically when something is too good to be true it insn't. There are no perpetual motion machines, and thats what this is. Engines waste tons of heat, but all the water is recoverable at the tailpipe. It could be condensed with enough tail pipe and collected back to the jar. Where do you make up all the wasted energy??
