Welding a cracked block.
cldonley
Robinson, TX
Thought I'd post up a few pics in preparation for welding the crack in my block I posted about the other day. Started the teardown yesterday and was pretty impressed by how clean the engine is internally.
Pulled the passenger side head and found the cross-hatch clearly visible on the cylinder wall. Noticed the Fel-Pro gaskets...did they use those in the factory in '69?
The speedo had 84k on the odometer when I bought the truck. It was a ranch truck. I wonder if it has been rebuilt, or if it really had low miles?
Viperwolf1
electron whisperer
I don't think those gaskets were available back then. Clean the center of the piston. I can see something stamped on there. This is usually the oversize.
cldonley
cldonley
Robinson, TX
1st, 3rd and 4th Pistons on the passenger side bank are marked 30 over. No visible markings on the 2nd. Looks like I'm gonna need to spend some quality time with a micrometer when I get this dude torn down.
roundhouse
Why bother welding a cracked small block ford ?
It may or may not hold
Un cracked blocks are tossed in the scrap pile by the hundreds
cldonley
cldonley
Robinson, TX
Well, mostly because fixing the little crack I have is a lot less expensive than starting over. I posted up about it the other day in a thread called "woe is me..."
nvrstuk
PNW
...but trying to weld that crack won't be less expensive than having to toss the "fixed/welded' block and starting all over again when the welded/fixed one dies...then you'll be out a ton of dough...
cldonley
cldonley
Robinson, TX
I've got a buddy with skills. We'll know if it's gonna work before I spend 10 bucks. All I'm looking at is labor right now. If it doesn't work then I suppose I'll start looking for a running exploder for a donor. Worth the risk.
nvrstuk
PNW
Go for it, price is right!
I stiitched together a marine block back in the day. Worked fine...
