OK, I’m trying to muster up the confidence to do this myself, I just finished putting on a new 3 1/2 inch suspension lift, sway bar, body lift and Duff extended radius arms.
I’ve already drilled out the existing leaf spring perches and moved the differential back 1 inch. I also added 6° shims in an attempt to correct my driveshaft angles.
Now to the question, how hard is it to weld on new leaf spring perches and get everything centered and lined up to where I won’t have any alignment issues later?
