Welding Body panels together
Izzy
Texas
So I've been thinking and hadn't seen any conversations about it but has anyone ever welded the grill to the fenders and close up the seem between the two? It would give it a nice clean progressive look.
I know the downside is if you need to replace a fender, you would have to cut the weld and re-weld it again but for a mostly street driver, maybe it would be worth it.
Most of the time, when I need to take a fender off, I take the grill and both fenders off at the same time anyway so I don't see an issue there.
Any thoughts on this? Pros\cons?
bax
Old Member
I think you already nailed the pros and cons. Although using a good seem sealer might give the same look without the commitment
Ding ding ding ding! if you want the seam gone, fill it. not with weld.
badmuttstang
redneck grease monkey
i would weld it as-well but if you don't want such a permanent joint use a lead kit from some where like Eastwood that way you could just melt the lead out and replace the fender and re-lead it
GrillMaster
mine are this way but my paint is 20 years old and cracking off. I'm sure it used to look great. welded rockers, fenders and grill. some pics in my gallery.
pcf_mark
I was going to weld the rockers to the rear fenders to eliminate that seem. The grill and fenders seems a little more extreme to me in case I want to swap a cam or somehting getting that off together is going to be a beast. It will bend a lot is my guess.
Izzy
Izzy
Texas
I'm not ready to do anything yet but was just day dreamin about moving on to the body work part of the build and that has been in my mind.
Good idea about the lead sealer though.
Broncotj0
Mankato, MN
I welded my fenders on, and I also welded the rear seam of the tail light housing to the quarter. I banged up a fender and it took me about ten minutes with a cut off wheel to cut it off. I took the new one and cut the front of the fender off where it bolts to the grill and burnt it back on. It was a couple hour job to get it cut off and fully welded back on.
76Bronco302
Sherman, Tx
As Im having my Eb body getting ready for paint an final adjustments on seams Im doing the same thing. The grille isnt matching up as good as I would like to the fenders. Im gonna weld the fenders to the grille, rear tail light caps to rear quarters and also the rear seam of the rocker to rear quarter. Should look pretty clean.
Entourage
Phoenix, Arizona
I welded the rear body fender seam and rear quarter/rocker seam. I wish I would have removed the grill seam on mine as well. It would look really clean. Post up some pics of how it turns out.
