welding question from a newbie
NJB71
Little Silver, NJ
ok, have never welded before, i want to learn, bought a cheap 90amp flux from harbor freight, I think the flux is .003....bought a couple of pieces of thin gauged steel from HD to pratice on, I lightly sanded surfaces, but DID not wash them down, and when I tried to weld, splatter, splatter, spaltter...so was wondering if any welders on here could give me some advice(besides buying a better unit, which I will down the road), why the splatter? how long should the flux stick out when welding? I have the system set on the lower cycle, maybe that is the reason?
Skiddy
are you using gas, it helps reduce spatter a lot. may have to turn it up a little more. your wire is more than likely .030, your stick out should be around 1/2" or so. Inside the lid there should be some round about settings to start with. and practice practice;)
N
NJB71
Little Silver, NJ
no gas, and if I remember, the factory setting was low...the wire would burn up, feed, arc and burn up as well...been reading a little about it, so I will try higher setting and keeping the speed at 6 or 7 and try that, but i def need pratice, alot...
phred
Earth
I am by no means a pro welder but the guys that taught me burned more rods and steel building ships during the 2nd world war than most of us on the board will ever see. First thing is be comfortable. Good lighting and practice. mig welding is fairly easy. Strike an arc and watch the pool of molten metal. keep the wire in the pool and move in small circles pushing the pool. I learned to hear the weld as much as see it. If you have you have your heat right and wire speed right the weld will sound like bacon frying. Nice smooth sizzle. I know there are a lot more precise ways to explain it but that's how I was taught. Practice makes perfect. I'm still practicing!
Skiddy
that's funny i can walk by someone welding and tell if their machine is set right just from the sound
ET
Dallas, TX
I'm not a pro either but my experience w/ flux is that it splatters a lot even w/ gas. It's very hard for me to see the weld pool. The Hobart welder I use has a chart on the inside of the cover that tells you the power settings for different metal gauge and w/ gas or not plus wire speed. I would see if you have something similar for a reference.
Eugene
N
NJB71
Little Silver, NJ
Eugene
a friend of mine who welded years ago said, 90% of welding is prep, I need to play around w/ machine, relax(was def a little nervous) and use MUCH better lighting, cause w/ mask on and light shining on metal, I was still blind....Thanks everyone....I love the process
302fix
When I picked up my welder from Airgas they showed me how to use it. They have classes on occasion. Check em out.
Phone: (866) 718-0685
Fax: (732) 752-6445
Address: 490 Stelton Road,
Piscataway, NJ 08855
khumphreys
Kinston
Flux core will spatter a lot. As far as the burn off, feed, and do it over again, it sounds like you might have the wrong tip in your gun or the tension on your feed drive rolls may not be tight enough or the drive rolls might not be the right size for your wire. The bacon sizzle is a sweet sound, once you get used to that sound you can set a welder without even looking at the knobs. A good machine to use is something like a millermatic 250 or an equivalent size machine made by lincoln.
bmc69
Ditto. You can also tell a lot from the cussing coming from the operator too, often at a much greater distance ;)
N
NJB71
Little Silver, NJ
so if the metal is bare, and I'm assuming since I bougth it HD, that it has been treated(keep it from oxidxing) a light sanding should suffice, in addition to correcting setting, Khumphreys is on to something, I was not sure if I had tension set enough, but I did what book said, turn machine on press trigger and let wire hit 2X4, if it starts to bend then tension is tight enough
Skiddy
followed by things getting thrown around then the grinder comes out or the arc gouger;)
blue bronco66
ocean county n.j.
i use the same flux core type welder.had lots of splatter.and a welder friend told me to heat the metal with a plumbers gas torch prior to welding.worked pretty good. try it.
DanWheeler
Kirkland, WA
Try slowing down your wire speed. When I get ugly spattery welds its usually because I'm trying to throw too much wire at the weld using my little 110v Lincoln.
Terkish
X2 on this. It works pretty good. Also i would turn your setting to high and your speed to about 4. Then practice, practice, practice...
Nightstick
Bronco guy
I am by no means a pro welder but I have built a few things (deer blind, feeder, etc) I can tell you that I wouldn't even attempt to weld sheet metal until I got clean welds on other easier projects. Obviously having a high-dollar welder helps, but one thing I'd get away from is using flux-core wire. You're always going to get a better weld using gas (unless you're trying to weld outdoors on a windy day). My advice is to stop by a local welding shop and pick up some scrap, and practice. Grab your hood and watch a buddy weld that knows what he's doing.
fordtrucks4ever
DFW
You will never get any good results from a fluxcore welder on sheetmetal. Go practice with at least 1/8" plate, angle iron, etc, until you have a grasp of how the weld lays down. You are not going to get the sound of frying eggs or bacon with fluxcore. It will be more of a shhhhhhhhh(well someting close), with lots of splatter. If you plan to do any panel repairs on a Bronco the only way to get decent results is using 0.023 wire and gas shield, either 75/25 or straight CO2. Now with some practice, you can do a fair job building bumpers, rollbars, and doing some non critical frame repairs. Rotissarie, engine stand, car dollies, and trailers are just a few things that a fluxcore welder is very good for. They are adequate for a lot of things, but will not yield a weld strong as other options.
scbronco
Sumter, SC
you said that someone told you prep work is key. they were right, but im not sure you got all the detail. i have never used any solvents to clean when using my mig. i make sure my peices fit together as perfectly as possible, i bevel the edges for good weld penetration, and i use a wire wheel on an angle grinder to clean any rust, scale or otherwise from the surface. i would never say my welds are fantastic, but they hold up, and look good enough for me. but like has already been stated, flux-core will always spatter to some degree, but the wire wheel can help clean that up some too... definitely stay away from sheet metal with that machine, you'll just burn it up or mangle it every time.
N
NJB71
Little Silver, NJ
was really only going to use it initially to weld my bungs to the muffler pipe....i for now will use the bung clasp that retrotek makes and once I have become comforatble using the welder, I will weld them on.......I just would like to learn the basics, and I appreciate the response to this thread so far...
