Welding Rust Spots
plate
Monrovia, ca
Ok from the get go I want to say that I have California rust not this back woods crazy stuff some of you post up.
All i want to do is fill some holes and patch some rust up.
First question can you just grind down and fill in rust spot. I know it is prefered to cut out and replace but im not in a position to do all that.
Second question for a fill and grind job like this would an arch welder work? mybe this should have been question 1 sense its the only welder i have access to.
thanks for your time if it seems like a really bad idea ill just end up waiting to replace the complete panels.
Tgure
Phoenix
I have plugged several small rust holes after cleaning them up with my mig. If the metal is real thin though which it probably will be you end up burning through alot and making it worse. So if it is one or two holes here and there I say try it put if you have a grouping of pinholes it would be better to cut out the section and weld in a patch.
;D
VT_Don
hole repair
Recently went down the road of repairing rust holes with a MIG welder. Used the copper plate kit from Eastwood.
The answer to your first questions is, yes. However the hole can not exceed about 1/4" size. Also, the surrounding material must be near perfect or you just burn a huge hole.
The second answer is, no. Even with a new, MIG welder sized with .02 wire the job was very difficult.
scottmcwms
Montgomery, TX
An arc welder will burn holes in sheet metal. I've successfully welded sheet metal with an arc welder, but I had to practice for several weeks before I could do it consistently w/o burning holes. The main problem is that you have to turn the amps down so low that it doesn't get a consistent arc. DCEP is the only way to go. AC welding is a no no. If you don't have the resources to get an inexpensive MIG welder then go to a body shop. Just a few holes will probably be cheaper to repair at a body shop than buying a MIG welder and doing it yourself. POR15 also makes a putty that is moldable. It works really well and dries very hard...like steel. I think it is only $15-18. I would give it a try for small holes.
