He's right Whoaa, at least as far as our shims go. This way the full head still sticks into the spring perch.
Ours come with two sizes of bolts, in case you're using them in some other brand of spring packs.
Sorry you had trouble with snapping the bolt beasterly. Was that the new one going in?
In a pinch you can use an Allen head cap screw of the same size (7/16") and you might have to grind down the head a bit to make it fit into the perch.
if you still don't have luck finding a replacement, call us in the morning and we'll get you another set out right away.
And while they should be fine at 40lbs as specified, stop at 30 or so just in case. It's still tight enough, even though it's supposed to be tighter.
Looks like we'll have to check some out. Hopefully you just got a defective one.
Well, "hopefully" for use anyway! %) Doesn't exactly do you any good at this point.
In some cases too, the difficulty installing the new one is that those holes in the leaves are pretty tight, and you need to align things pretty precisely. And still have to tap the bolt through with a hammer.
Good luck. Let use know tomorrow if you need more.
