Look on WH on line for instructions. Nobody seems to want to put a pc of paper in a boxof parts anymore. I really dislike having to look up instructions on my phone. Too small, have to scroll too much, royal pita because I can't listen to my tunes then because my phone has to be plugged into my amp for Pandora.
What a whiner...
Can I get witness!
The only instructions on the WH website are for the VSS / Speedo assembly. The accompanying video is just Mitch talking about how awesome the product is. There are instructions for the DIY version, but they don’t exactly apply. The Advanced Adapters instructions are only for Jeep/Scout D20’s.
But I noticed that the AA says explicitly not to use a gasket, just silicone. I was curious why the kit did not come with a gasket, but I have a full rebuild kit, so I wasn’t worried.
Should I pull the gasket?
And how much endplay should this unit have? It’s loose, like probably .030” loose.
The AA site says they have pre-assembled and adjusted for shims. My unit came in a AA box, inside a WH box.
I suppose I should call WH. But I really wanted to build it this weekend.
[mention]DirtDonk [/mention] Paul, do you know anything about this unit and what the installation procedure is?
Thanks,
Hinmaton
