WH adjustible track bar
savage
savage
Bronco Nut
Renton
I torqued the upper one at 110lbs, new grade 8 bolt & nut.The axle was tricky wanted to torque to 155lbs,but when I tried the hole for the carter key it was covered by the castle nut ear,didn't want to back off so went to 200lbs lined up perfectly .
savage
savage
Bronco Nut
Renton
torques
Here are some of the torques for the front suspension from ford factory oem shop manual for my 74.
englewoodcowboy
Lick Creek Restorations
It looks to me that the adjustable track bar, the first bend on the fixed side starts shorter that the factory and the angle applied looks a little less. Just cfor curiosity sake, has anyone cut a factory track bar and weld on an adjustable heim and bung? Seems like a simple DIY kit could be in order...
I think quite a few people have done, or at least tried that in the past. But I haven't seen any mention of someone doing it in the past few years.
And I don't think many companies with much to lose would offer a DIY kit that requires welding, or threading, by persons unknown, for something so critically important to the safe operation of a vehicle.
It's not actually a bad idea. It's just one that most companies, ours included I'm sure, wouldn't touch with a ten-foot pole.
In my opinion anyway...
VT_Don
Track bar is my design and fab. Is a 3/4" threaded, tie rod bar as used on oval track modifieds. Required adding a dog leg bend, welding on eyes, and machining a RH-LH threaded adjusting screw. Fits and functions perfectly throughout full range of suspension travel. Advantage being, does not have to be removed for adjustment. Offered as a suggestion for what our market requires.
savage
savage
Bronco Nut
Renton
Nice fabwork!!!When you think adjustable, your way makes for a easy less hassle free solution.
