Nightstick
Bronco guy
- Feb 6, 2010
- 2,929
I'm installing the above kit. Two issues so far and I need some answers... First thing is for those of you who have purchased the kit, did yours come with the fittings that attach the flex line to the caliper? I just see a hole in the caliper and nothing included to attach the hose to it.
Second and more importantly, were your calipers easy to install, or did it require a little persuasion? The calipers and mounting holes did not line up very well, which I think is what is causing my biggest problem. Both calipers are on, and the drivers side hub WILL NOT MOVE! The inside pad is in full contact, while the outside one is loose. The passenger side has some friction, but turns by hand. Any suggestions???
