69_ColdDuck
Newbie
- Aug 15, 2016
- 37
Hi all,
I recently installed the WH hydroboost unit on my 69. My system includes an F150 gearbox and pump and a power steering cooler in front of the radiator. I've bled the death out of the power steering system and am certain that is not the issue. What's happening is that with the power steering pump full to the brim with fluid, at start up, all the fluid is sucked into the system and I have to add about 3 or 4 ounces quickly to keep it from sucking air in. This results in the fluid at the "cold" level. While running, the fluid stays constant at the cold level. The system operates beautifully in the short little drives I've taken - can't believe the brakes work so well...However, when I shut it off, the fluid moves back into the pump and overflows about 3 or 4 ounces. So, I'm trying to figure out if the cooler is the issue - with the additional hose running to and from the gear box and the hydroboost, there's a lot more fluid in the system. WH says they do not like running coolers with the hydroboost, so this may be the problem. Anyone have a similar issue that you resolved? I was thinking possibly finding a way to add an overflow reservoir or installing a check valve to prevent the fluid from running back into the pump reservoir. Any ideas? Thanks!
