techlaf
- Jun 28, 2008
- 692
So my 9" cracked and was welded for repair, but still leaks. '75 Bronco.
I want to buy WH's '76/'77 stronger 9" rear housing:
https://www.wildhorses4x4.com/produ...-Large-Bearing-Large-Bolt/Bronco_Rear_Housing
The issue I have is the spring perches are welded with 6 degree angle so you don't need shims for 2.5-5.5" lift suspension leaf packs. My truck has WH's stock height 10 pack and don't intend to change that out anytime soon.
Will I get vibration using the angle the spring perches are welded now?
Can I purchase the shims and put them in backwards to correct the angle?
Or, do I have to cut them off and weld to the stock angle?
