What carb to get?
beerthirty
Lakewood, Co
Im looking to get a new intake and carb and I was just seeing what you guys would suggest. I was thinking of getting the wieland stealth intake but I cant pick a carb. I currently have the stock intake and carb on my 1969 302. Do you like the stealth intake or would you pick something else. I would like to get something that will work good on both street and trail as I use it for both. And also would would you say to change anything else while I got it torn down. Thanks for any advice;D
gpete
Elderbrock performer intake and 470 cfm holley truck avenger carburetor
gjrock
Anacortes,WA
I think the choice should be the 470 TA or the Q-jet from Bc Broncos.The stealth and the edelbrock are both good choices also.
Madgyver
Bronco Madman
auto or standard?
I have a Q-jet on my yellow77, a 4brl Holley on the green77, An edelbrock on the firebronco and blue75, and a Holley DP on the copper77..
The 1st 2 are the best drivers, the edelbrocks works but not how I want it to..
Rockin69er
I have a stealth intake and love it!! I hope you have an aftermarkey hood. As for the carb?:? I have tried them all. I love holleys and raced with them for years. I had better luck with an off the shelf 600 than with the 470 TA I bought (wish I had kept the receipt) Less than a month old, its for sale;D ;D
B
beerthirty
Lakewood, Co
Alot of people have said that they have had problems with the holley T/A carb what problems have you guys seen with them? Like Rockin69er said he had better luck with just a plain 600 carb. Ive read the tech article on how to make a holley carb into a T/A by changing the vent tube and a few other parts does this work as well? I just dont want to buy a new carb and not like it. But for some of you it sounds like it works great.
DonsBolt
Chestnut Hill, Mass
I would go with a Edelbrock performer 289 part number 2121
I have found Edelbrock casting is better than the stealth
The T/A tend to run rich which is why some people don't like them
The only problem I see with the T/A is 470 can be a little small, but 670 is to big for a stock 302. If they made a 570 T/A I bet it would be perfect.
Rockin69er
how much are you selling it for? And what problems did you have?
It was the best idling carb I have ever had. Around town perfect, on a flat highway no problem. If I went up hill or under a good load it would run great to 2300 rpm then sputter like the ignition was bad and blow black smoke until ~3000 rpm then run great again. I tried every size power valve, jetted it up and down 1 size at a time for a total of 6 sizes, changed the vacuum diaphram, tried 3 different shooter sizes and 3 different accelerator cams. During all this it never changed. Bought a 600 and did the mods in the tech section, runs fine but is not the greatest when playing in the rock.
Called Holley and they said sent it back with the receipt and they would take a look. They said some of the 470's had an internal problem. About 2 days after I got it my hard drive crashed (bought it over the net) and took my receipt with it. Always print those out!!!!
Bucky
New Bern, NC
Street Avenger 570 has worked great for me! I don't do alot of off roading so I didn't need the TA! As for Intake, I agree with mos I think I would go with the Performer 289 if I had to do it all over again! I have a RPM Air Gap and it's OK, but not enough low end grunt!
DonsBolt
Chestnut Hill, Mass
SteveL
Huge chevy guy
Hawthorne ca
I just grabbed a q-jet from the boneyard off a motor with the same ci. The ones from BC are nice. I may have to get one of those for the wifes 66.
Buldozer
Bronco Virtuoso
God's Country
The T/A's have their problems...I am currently running one and chasing a problem similar to Rickin69er, but not nearly as bad. The older Holley double pumper carbs run much better (try perfect) IMO, however, they flood out when off roading. I have made all the mods to them and they still flood out a lot more than the T/A. So now I am running the T/A and I keep working on it and it is getting better, but still not perfect. I may try swapping the metering blocks with an older carb if they will fit. The problem with the T/A seems to be in the front metering block. Good luck.
Rockin69er
beerthirty I sent a pm.
After reading my reply on the 470 TA it sounded like the secondaries were coming in too soon. I checked the carb this morning and it had the heaviest spring they make.
For all others following this thread I just got off the phone with Holley tech. They said the 470 was designed for the 258 6 cyl. It does not have enough air flow for a V8. Causing the problems I discribed earlier.
blubuckaroo
Grease Monkey
Ridgefield WA
I put in an Edelbrock 1403 and have been happy with it. The only thing I've done to mine is to put the stiffer metering rod springs in and lowered the fuel level a bit. Works great so far. Mine runs good even on steep side hills.
