What did I do now?
Okie69
Finally got the Bronco running like I wanted. Took it out for its inaugural Sunday drive and everything was going fine. Stopped a stop light and took off in first, when I tried to shift into second it wouldn't budge. Now it won't shift at all from the column not even into neutral. I can make it shift between first and reverse from underneath but the front shifter won't budge at the transmission. It never made a noise or acted funny in any way...help!
It's a pretty stock '69 302 3spd
Okie69
Okie69
A buddy said something about old transmissions building up pressure and it being a quick fix? Any truth to that?
bronconut73
Column shifted 3 speeds are notorious for getting the linkage jammed. I had friends that used to keep an old rag or glove so they could yank the linkage from its jamb without getting their hands greasy.
broncnaz
They dont really build pressure that would cause the transmission not to shift. Make sure the first/reverse lever is in the middle position then try and move the 2nd-3rd lever. It needs to be set in the middle postion as well then. Once you get it moving again you probably need to readjust the linkage
Billsboat
Rowlett tx
I had a Buick skylark years ago that did the same thing. When it got stuck I'd open the hood, grab the linkage and yank up till everything was free. Ahhh the good old days!
Fairlane514
Houston
There is a 3 speed floor shift for sale in the "for sale" parts section……one of the best mods I did to mine.
Okie69
Okie69
Messed with the linkage a little and cleared it up. Never touched the shift linkages before so thought it would be a bigger deal than it was. Thanks guys
Okie69
Okie69
But the only reason I've kept the three speed is because of the nostalgia of the column shift! Haha
bax
Old Member
It really is part of the anti theft device. 3 on the tree is a dying art.
bmc69
Back in the day when my '69 was a daily driver for many years, I couldn't count the number of times I had to get out at a stop light, pop the hood and re-align the shift linkage to un-jamb the tranny. Embarassing..often. ;D
Okie69
Okie69
Haha well now I know. First time I've had any trouble with it.
jdbronco
Panama City Beach
Haha I've had to do that at a stop light before. If you are in too big of a hurry and going from one linkage to the other it can jam it up. I finally corrected how I was shifting but at one point I could crawl under in the dark and find it blind.
Okie69
Okie69
Haha yep, drove it for a couple of hours yesterday without issue after unjamming it. I think I just got a little sloppy trying to go to the next linkage.
