What does this mean
Tulsa76bronco
Tulsa76bronco
Yep sorry just figutpred it out thanks guys, is the only area that tells me the paint color on the inside of glove box
Viperwolf1
electron whisperer
On the sticker on my door post it says front 2280 and rear 2480
Those are the gross axle weight ratings, GAWR. That is the maximum weight each axle is rated for as long as you stay at or below the gross vehicle weight rating, GVWR. In other words, you could put 2280 on the front axle and 2480 on the rear axle as long as the total doesn't exceed the GVWR, which it will. The GVWR is probably about 4500 lbs.
2480 on the rear axle is going to be a light duty, small bearing axle. The heavy duty, large bearing axle had a GAWR around 2900 lbs.
okie4570
NW OK
There's a location for it on the door jam sticker, but it's not usually actually printed on there.
Look at the number or letter to the right of the 092 on your warranty plate on the back of the glove box door.
