What driveshaft to get
JohnJohn
Richmond
I am on a quest to get rid of a rear driveline vibration and am down to the driveshaft or the ring and pinion needing to be replaced.
The cost will be about the same to replace each but I am going to replace the driveshaft first because it would take the least amount of time to replace.
Any recommendations?
I was looking at the Tom Woods shafts or the Wild Horses Extreme Duty shaft but am up for suggestions.
68 Broncoholic
WA
I've been using Tom Woods with great results. Plus they will replace it if it breaks! ;D
JohnJohn
JohnJohn
Richmond
Any idea how much the Tom Woods shafts cost? I would like to stick around $300.
sprdv1
REBEL
Tom Woods for definite.. Google em up, give em a call.
Shiner
Mooresville, NC
Carolina Driveline- Spartanburg, Sc
$188 brand new front shaft, WAY nicer than the $300 rear one I bought from somewhere else.
Told him the length I needed and he asked "is that with about 2.5" of lift? If so, that measurement is right on with usual." Guess my lift? ;D
Ordered on a tuesday afternoon, on my porch thursday at lunch.
Can't beat that to me.
68 Broncoholic
WA
I've purchased some cheaper drivelines and found when I cut into them to shorten or lengthen, they're almost as thin as paper. Be carefull of that.
If I remember correctly, I paid around $200 from Tom Woods per driveline.
You have to deal with shipping but it will be at your door in a few days in a nice protected tube.
Zillacon
Hackin Away!
Find a reputable local shop. Usually must less!
What makes you think you need a DS or Gears? Did you check angles, U-Joints. Have your shaft inspected and maybe balanced by a local shop before throwing money at Ghosts.
lillsteve
Granbury, TX
I am using a rear extended driveshaft from Toms Bronco (Parts 2950) after I blew my factory driveshaft on a 3.5” James Duff lift. I have been very happy with the driveshaft as I am now vibration free although my Bronco has not yet made it past the end of the driveway since our cold California weather set in.
Brian B
Same experience here. I bought both the front and rear on seperate occasions and got them in like 2 days.
JohnJohn
JohnJohn
Richmond
Thanks for all the good input guys.
I am about 99% sure its the driveshaft or ring and pinion.
I had my stock rear shaft balanced and rebuilt by a local shop that does nothing but shafts and they said the splines were worn out and they could fix it for me for $100.
Problem is I would have a fixed 30 year year old shaft and I would rather not sink any more money in the old one.
As for my ring and pinion... they are out of an old Bronco. I had a shop inspect the center section before I ran it and they said the ring gear looked slightly warped but to run it and see before dumping money in it.
JohnJohn
JohnJohn
Richmond
Update:
I went with Carolina Driveline for my shaft. They were good to deal with over the phone and made me exactly what I wanted. Quality looks great.
I got a long travel DOM shaft with greaseable joints. $225 Shipped to my door
Only problem is the vibration had not gone away so next is a new ring and pinion set.
Wish me luck.
Shiner
Mooresville, NC
Man thats tough to hear.
Glad you were happy with the CD product and people though (since I was one who recommended). ;D
Good luck chasing that vibration.
