airman said:
Monkey, what side of the frame rails does your steel mount to the floor? I really like your set-up. It looks like the outside so I won't have to remove my fuel tank to bolt it down? How do you fasten the box to the rack?
Jeff in AZ
Jeff,
The way I have it mounted, it does mount inside the frame rails, but you don't have to do it that way!
The frames I built, I purchased all the steel from Home Depot. Two lengths of L and two lengths of box channel. Measured, cut, welded. The box slides forward 2" on a track which is designed for a hidden keyboard (Lowes had it, I can get a part # if you need it). The track had to be trimmed slightly & then I created a "stop" too. IN all it was a half day job. The painting took longer.
But, you could have easily spaced the support brackets further out, alongside the exterior of the box, which pushes them to a point where you don't have to drop the tank.
If you need more photos, let me know!
Bill
