Last night I put the check ball weight in and also went back to the 52 jets. I'm calling it good now! It's running smoothly all the way through the range with no discernible misfire. I can get the choke off pretty quickly, but not so quickly that it seems wrong. So if anything I'm probably still a bit rich, but probably not very much.
One other thing I can do now that I haven't been able to do for a few years is start up, even on a slight uphill, without touching the gas! I have the idle at about 900 rpm according to my tach and I can pretty easily get it rolling at idle without stalling the engine!
I do have a couple minor issues. One is that when I'm coasting at idle and hit the (hydroboost) brakes pretty hard the idle speed will drop. If I also turn the steering it'll drop a bit farther. A week or so ago it would sometimes die when that happened. It's not dying now(just making me think it will). So I probably won't worry about it for now.
The other is that when I shut it off hot and try to restart in a minute or more later it'll be flooded. I've had this issue before, but it'd be nice not to. It'll start right up if I hold the throttle open to clear the flood, but it'd be nice if I didn't have to do that.
Anyway, I'm getting close to leaving for Moab and I still need to get the motorhome ready. So while I might still find something to putz with, I think I'm going to call the Bronco done for now!
