bcmbcmbcm
almost there!
Thanks! That page from the shop manual helps. I am getting close to figuring it out. Looks like the ‘equalizer lever’ is there for sure.
Not sure though if these are the correct forward and rearward mounts though.
The forward mount has 1 hole in it- as it should, right, for the one cable from the pedal?
The rear mount looks like it had three holes on it…but on closer inspection, it looks like the three holes are on a piece of plate that was welded up to the original mount. If you look closely at the pic you can see how a new plate was welded up to support a junction for BC -AN fuel tank fittings that are no longer used.
So, if I understand what I need to make this work (if these brackets are right) I will need to do the following:
1. Get an equalizer
2. Get three of those clips
3. Get a new set of cables
4. Cut the plate off the rear mount and re-drill the holes
Does that sound right to you all?
1. Get an equalizer
