What is this??
cwarren87
I'm rewiring the bronco and am stumped by this. The factory diagram says this is the mechanical stomp lamp switch, well what is that? I know the brake light switch is in the brake proportioning valve so it can't be that. Help! what does this do and where does it go?
Thanks guys!
eds66bronco
Essex, Vermont
clips onto the brake pedal where the master cylinder push rod connects to it. that is what activates the brake lamps. the proportioning valve switch is only a warning lamp for loss of pressure balance in the braking system.
WyleCoyote
Yep that's the brake light switch. You also need two nylon bushings (a top hat one and a regular one) to make it work
grant_71
X2, Mine I had to put a dab of silicone on it to hold it to the pedal because it never wants to stay in the right spot.
Smokeater11
Auburndale,FL
Would a picture of one installed help? I can go to the shop and get a pic of mine in place so you can see how it's oriented on the pedal.
Viperwolf1
electron whisperer
Brake light switch.
cwarren87
cwarren87
Thanks, everyone, for clearing that up. I can stop having headaches and move on with my life. Viperwolf, that is one hell of a diagram! Thanks again.
