ChrisHowardMD
- May 10, 2022
- 2
I have restored an old Mustang, but this is my first Bronco and first post here! This place has been a ton of help and I have found answers to all of my questions except this one.
I bought a giant project that has been apart for 20 years so that I could do everything on it - its all about the journey on this one. I stripped it to nothing, blasted the frame and am working on completing the rolling chassis first. So far I have WH 5.5" lift springs, Tom's extended radius arms, f250 front shock mounts (not installed yet), WH adjustable track bar, Ruff Stuff 1-ton TRO Y-link, and a rear inboard shock mount. I want to run 37/12.50/17's and full widths. I bougt a cheap set of worn 37/12.50/17s mounted on some 2012 dodge wheels (5x5.5) for mockup. I found a set of 1973 F150 axles and am working on getting them setup. I wanted some disc axles, but they are impossible to find with the weld-on wedges. Far in the future I plan on doing a Siper'd 302/351, C4, and D20. Body lift TBD.
For the rear I stripped it and welded new HD perches (had to rotate them 12* to get a good pinion angle!) and will be doing the Ruff Stuff disc conversion.
For the front FW HP 44 I mocked everyhing up to get the correct pinion angle (12* up for my setup), and welded on new wedges at the stock width. I used the poly 4* bushings that came with the radius arms so I can go up to 6* or down to 0* in the future if needed. Then I cut-and-turned the C's to get 6* of caster. I cut the stock track bar mount off the original D44 and welded it onto the FW HP 44. Then I added the WH track bar riser. I probably should have just used an aftermerket track bar mount, but I had already ordered it and thought I might as well use it. So far so good, just a bunch of work, especially getting the wedges and C's off!
Now for my question - I plan on doing the standard chevy disk brake swap form one of the vendors, nothing fancy. What knuckles should I use? Bronco or F150?
I currently have the Bronco knuckles on there so I could get the higher tie rod position and the Ackerman would be right for a Bronco. However, the more I researched it I realized the equation for Ackerman angle has track width and wheelbase, so I guess neither knuckle will be perfect. Also, is there a camber difference between the two knuckles when installed on F150 C's? The C's ball joint surface was measured at 0* before and after the cut and turn. I have read that some need to use the shims with the disc knuckles on drum D44s, but I can't find any info on the drum knuckles. As I'm typing this I thought of another issue - Will the larger F150 U-joints even fit through the Bronco knucles?
Thanks in advance for the help,
Chris
Chris
