I read this somewhere a month or so ago when I was looking for the calculations to run a single pedal/dual mc manual brake combination system... well, here it is, I accidentally ran across it tonight.
Just trying to show how much more leg pressure is going to be needed from a .75 bore mc to a 1.00 bore mc a lot more than we can imagine. 77.7% MORE pedal force to operate a 1.00" bore mc than a .75" bore. That is a lot of pedal force.
This is from Mark Williams brake tech page:
" Slack comes from two factors: retracted pistons must be moved back out, and misalignment caused by deflection in the axle and housing mis-alignment. One of the most common misconceptions is that a larger master cylinder will create more pressure. While a larger master cylinder creates a larger displacement, it takes more force to create the same pressure as a smaller bore. While a larger master cylinder will take up system slack with less pedal stroke, it will take more force to create the same system pressure. The result after adding the larger master cylinder is a harder pedal which needs much more pedal pressure to create the same amount of braking force. For instance, moving from a 3/4" master cylinder to a 1" requires 77.7% more force on the push rod."
