What size flexplate / torque converter
noot74
Washington
I finally figured out why my tranny would not mate up with my engine. I should have checked before I started assembling, but that would have been too easy.
My question is this. My flexplate is from a 75 Bronco to my knowledge and the holes for the torque converter studs are 10.5" apart across from each other. My torque converter in my C4 measure 11.5" across. Anyone know which part is right? Do I need a new converter or a new flexplate?
Thanks,
Corey
measurements edited since I was backwards
DebosDave'72
Bozeman, MT
I would think the flexplate would be the cheaper part to replace... what transmission and what did it come out of? What was the flexplate hooked to before?
DD
N
noot74
Washington
From what information I have, I think the 11.5" is the original, and someone told me the 10.5" is for a high stall street engine, odd that it came in my bronco
DebosDave'72
Bozeman, MT
Ok, from what it sounds like you got a new c4? and you took a c4 off your current bronco? Your current bronco came with a 11.5" bolt pattern flexplate, but the new transmission came with a 10.5" pattern converter? Can you get the flexplate that the transmission was bolted to? I would try to find a flexplate with the proper bolt pattern for the converter that you have, a new converter I think is expensive, and you wouldn't want to use a used one without rebuilding.... I would think if the c4 came behind a small block ford, you could use the flexplate that it came with...
DD
DebosDave'72
Bozeman, MT
What vehicle did the transmission come from? From what I have been researching, the bronco will need a 164 tooth flexplate, I looked at Summit, and their 164 tooth flexplate is 11.438" The 10.50" flexplate is only 157 tooth, so unless someone knows of a 10.50" flexplate that is 164 tooth, you may need to change to a torque converter that has the 11.438" pattern...
Sorry, I know I am not being much help here... Hopefully someone will chime in that knows something more
Dave
NicksTrix
go get your converter bolt pattern changed. the 10.5 pattern is stock bronco but only a very few years (74ish) and new 10.5 flex plates for the bronco are near impossible to find.
trans guru broncohowie gave me the ford part number a while back and it's in my notes somewhere. i tried buy couldn't come up with one.
the 11.5 is far more common.
find a trans shop that rebuilds converters or send it to one to have the change done. not that big of a deal, but might be more cost/time effective to get a fresh converter with the big pattern and carry on.
sorry to hear you got mixed up parts right now.
nick
N
noot74
Washington
OK,
I mixed up the numbers from outside to coming in here to type. The torque converter is the larger pattern, the flexplate is the smaller pattern.
Here is the scoop. I bought a 74 with factory AT. The torque converter has a date of 2000 on it. I got my flexplate from a friend that has in yellow writing 75 Bronco 302. There was no flexplate with the 74 that I picked up.
My flexplate is 164 tooth, but the bolt pattern is approximately 10 1/2"
My torque converter is approximately 11 1/2" across
These measurements are from middle of hole/bolt to same on the other side.
There is a shop that will order me a new 11 1/2" flexplate for around $50
Also thank you everyone for all the input
76 bronco J
whole issue with the mix up that usually happens as said with mid 70's broncos as well as a few other car models is 98% percent of the time you have 164 tooth flexplate with a 11 1/2 " bolt pattern for the big bell housing & 157 tooth flexplate with a 10 1/2" pattern for the small bell housing-- for some reason in the mid 70s ford used some 10 1/2 " pattern small bell housing convertors with a snout welded on the center to make up the depth to fit in the big bell housing then made special flexplates for them- the original 28oz imbalance flexplates with 164 teeth & the 10 1/2 bolt pattern are rare as well as the convertors & if ever going to the newer 50oz imbalance 302 motors finding a 50oz imbalance 164 tooth flexplate with a 10 1/2" pattern is impossible so it's easier & cheaper to replace to convertor to the regular style-- keep in mind that when using the newer 302 motors flexplates for the overdrives with fit the 11 1/2 " pattern C4 convertors
NicksTrix
if your 10.5" flexplate is in good shape, i'd be interested in it.
lmk
nick
