Does it need primed? If so finish sanding with 180, degrease, and then prime with etching followed by a high solids (HS) primer. If you have an epoxy primer you can skip the etching and go straight to primer. If you don't need to prime then the best way is to finish sanding with 320 and scuff with a scuff pad. Degrease, then apply etching and then sealer, let flash and then paint. Or if you have an epoxy sealer skip the etching.
Check the primer TDS (technical data sheet) for the substrates and mix ratios to see if you can use the primer as a sealer.
Another thing.... I wouldn't get in the habit of using lacquer thinner as a final degreaser for painting. It can react to primer and paint. It will/can lift the edges and you will get a ring around it, especially enamel and lacquer. Use a dedicated degreaser for automotive painting. If you have a Keystone Automotive (aftermarket distributor) they sell a inexpensive degreaser that works great.
