bronko69er
EB Addict
I could not be happier with my Ballistic Fabrication Chevy TRO setup
Good price for a complete kit and extremely strong
Nice fab work there! ;D
Anthony,
I respect your opinion as well. One of my biggest complaints about people running Heims/SRE's is that they think they are indestructable. This gives a false sense of security and due to the lack of them needing to be greased it leads people to beleive that they do not need to check them as a maintenance item. With all that has been said here about heims/SRE maintenance on them do either you or Chuck include all of this knowledge about the issues of installing and maintaining or is that assumed that the installer already has this knowledge?
Ben
Did you weld the inserts in? Again, looks really nice.
Anthony
. . A 1000 mile Baja will put them through more use than most will see in a life time on a normal rig.
I always love these assumptions. What makes you think one race is equivilent to life time on a normal rig. Most tre last 20-30 years in my experience, and the ones that are about to fail are generally pretty obvious and sloppy. Now i have no problem with hiems on a trail rig mild street rig. My issues with hiems is there quality and longevity. Almost every trip i've been on in recent years someone has had hiems that had failed or were in the proccess (loose and squeaking like hell) The Three that come to mine right off the top of my head two where PU set ups one was stonecrusher( I am not knocking either product they are both good looking products. I would even consider them if i was not capable of building my own.) The one on the stonecrusher he had already replaced one with the spare and now was driveing around looking for another. Luckly it was in moab where it is actually possible to drive into town and find one. Where do you go when you need to replace a hiem any other city in america? If your running TRE's you drive down to napa, autozone, carquest and there going to have one in stock.
What is the best tie rod or hiem joint set up? Who makes it?? I have head a lot of BS about different hiem joint set ups?
Look at the can of worms you opened up.
In my opinion if your running a daily driver/weekend wheeler stick with the tierod ends even stock sized is fine although F150 or ch#vy ends are a good upgrade. 1 if you break one you should be able to get a new one about anywhere. 2 no modification needed. 3. There DOT approved so no hassle at inspections if you have them.
If your into hardcore wheeling or just want to look cool then go with the hiems.
Personnally I wouldnt run hiems nothing really against them other than having to modify stuff to make them fit. I dont do hardcore stuff but I have been through a lot of rough stuff and my stock tie rod ends have held up fine. My other theory is that mostif not all of the hiem setups use extremly big DOM tubing that is considerably stronger than the stock or conversion tierod if you end up hitting something with a stock tierod it will usually just bend. With the hiem setups if you hit something they are less likely to bend and your more likely to have breakage somewhere else like a steering knuckle. Personnally I'd rather bend a stock tierod then possibly break a steering knuckle. Keep in mine I havent heard of this actually being a problem with heim setups but its just my opinion. Its kinda like ujoints you need a weaker leak somewhere to keep from trashing the real expensive or more critical parts. I've seen knuckles break on tierod setups also so its not a given that one is better than the other.
Why yes, yes I did. Thank you! ;D
what all do you have to ream out for this kit to work since your tie rods are on top did you have to ream both knuckles and pitman arm ...etc
Should also be noted that the NYLON SRE's do not have a 28000 lb load rating... more like 23000...
http://www.fkrodends.com/KMX KMXL.htm
