- Dec 18, 2003
- 5,045
Thinking about selling the bronco, and wanted to get some opinions from you guys on what you think I could get for it.
1977 Cut
Speedo reads
351w reman with ~1,000 miles on it
Serpentine setup
Power Steering
Power Brakes
C4 rebuilt with mild shift kit, ~500 miles(Nationwide rebuild)
1" body lift
Full kayline soft top with riser, not in good shape
Stock front seats
Expedition middle center rear seats(integrated shoulder belt and Latch system + foldable)
Stock rear tank
Carter P4070 electric fuel pump
Motorcraft 2150 carb
BF Goodrich A/T 32x11.50R15 on fullsize bronco aluminum 15x8 wheels
Prerunner front bumper
MileMarker SE12000 12,000lb winch
New windshield and gasket
Cherokee wiper swap
All lights work
Original spare tire carrier
Original dash pad in good shape
Diamond plate bed rails
1.5" wheel spacers in front
2" wheel spacers in rear
Extras, not installed:
Gear Gawker for the transfer case
Tom's 6 point family roll cage
nearly complete mustang EFI with intakes and BCB 351w adapter and throttle/kickdown cables
New full length soft top with new riser
5.5" suspension lift
spare t-case
original fender cutouts(to make back into an uncut)
2150 carb for parts
Hood gas struts
4 1981 Fullsize aluminum wheels
5 stock steel wheels
8 stock hub caps
Rear inside quarter panel covers, bare masonite
Tilt column
Galvanized aux tank
1" wheels spacers for the front
The bad:
it was in a collision at the front passenger side at some point. It has been repaired and you can not tell it was hit without lifting the hood. It tracks straight and looks straight.
There is body filler on the rear quarters where the lower and upper quarters meet, obvious rust repair.
The hood has a crack at front lip, but it doesn't seem to be spreading in the years I've had it.
There is a piece of diamond plate steel welded into the body between the bed and front floorboards, rust repair.
The speedo is not accurate(bounces and generally reads wrong, not a speedo gear problem)
Driver's door is rusting in the front bottom corner, not bad, but has some through holes.
Front floorboards were welded over the old ones.
Bedliner is peeling from front floorboards.
1977 Cut
Speedo reads
Serpentine setup
Power Steering
Power Brakes
1" body lift
Stock front seats
Stock rear tank
Cherokee wiper swap
All lights work
spare t-case
2150 carb for parts
Hood gas struts
8 stock hub caps
Tilt column
Galvanized aux tank
The bad:
![2bd5db70.jpg](http://i1010.photobucket.com/albums/af224/lonesouth/77%20Cut/2bd5db70.jpg)
![def8a148.jpg](http://i1010.photobucket.com/albums/af224/lonesouth/77%20Cut/def8a148.jpg)
![e3190c79.jpg](http://i1010.photobucket.com/albums/af224/lonesouth/77%20Cut/e3190c79.jpg)
![P1000440.jpg](http://i1010.photobucket.com/albums/af224/lonesouth/77%20Cut/P1000440.jpg)
