What's with the photo uploads?
Znavgtr
Nipomo, CA
I have nothing but trouble uploading pictures (jpgs) and they are all within size limits. I actually get a pop up that says my image was uploaded succesfully, but yet it does not show up in my gallery. Makes me frustrated. I wanted to show you all my Bronco - 'Nator! :cry:
Tito
CB Fire Starter
Bakersfield, CA
Maybe they are within the pixel range but not the kb range? I know sometimes it takes time for images to show up in the gallery (admin approval)
casadejohnson
Bronco Alchemist
I have had the same issue tonight. Uploaded six pictures but only one showed up.
admin
Administrator
Just your friendly, neighborhood webmaster...
Phoenix, AZ
Neither of your accounts show any issues or pending photos to approve. If you could both email me a couple of the files you're trying to upload I'll see if they might be causing the problem.
Znavgtr, are you trying to upload pics into the forums or the Gallery. I know casadejohnson's issue is with the Gallery per his other post.
backwoodsbronco
deepinaholler,KY
Jon ,I am having the same problem.When I try to upload into the gallery I recive a pop up that says succesfull.but I still have no pics in my gallery. Any help would be great.
Tito
CB Fire Starter
Bakersfield, CA
Hey Jeff, did you upload more than these 15?
Be sure in your user cp options to check the box for "check if you are in gallery"
admin
Administrator
Phoenix, AZ
I seem to be having the same problem. I started my gallery today and only a few of the pics would load.
I see 5 pics in your Gallery. Did you upload more than that? If so have you tried uploading those same files again? I'm trying to narrow down whether it's an issue with specific files or something on my server.
seahawkfan
Vacaville, Ca
I actually had 12 at 1 time. Not sure where the other 7 went now. I tried to load them a few times. I'll try again in the morn. I don't even see my gallery listed now. Thanks for looking into this.
admin
Administrator
Phoenix, AZ
seahawkfan, do the above also. That will help find your Gallery easier.
admin
Administrator
Phoenix, AZ
I think I've found the problem many are having. If the filesize is too large the software eventually times out trying to upload and skips to the next one. Unfortunately when it skips to the end the default message is to say that they've been uploaded successfully, which isn't the case.
If you're uploading more than 1 photo there will be an intermediate page that comes up with check boxes. See the screen shot below for an example. If you don't see this page (ie. it hangs for a while and then the message "successfully uploaded" pops up) then your files were probably too large.
There's an updated version of the Gallery software, so I'll probably upgrade in hopes that they've fixed this bug.
