Wheel Bearing Grease Packer Tool
L
Lon L
New spindles and bearings came installed, they seem lite on grease. I didnt want to pull them out for what could be an easy fix with a tool like that. I would gladly purchase one for $20 to avoid removing the bearings and seals.
73azbronco
Don't get me started on pre-rubber gloves bare hand bearing pack... I did have softer hands then though....
SC74
You're going to have to remove the seal to get to the inner bearing regardless. It's not like a Dexter EZ Lube trailer axle. There is no set up that I'm aware of to allow you to grease wheel bearings on a Bronco without removal.
Hey Lon. Not sure I understand this. How can the spindle be pre-installed? Answer, other than for shipping purposes, it can't.
And since you can't install a spindle while it's in the hub, it has to be removed or I'm not understanding what you're saying.
I can see someone putting things together for shipping purposes, but they expect you to take everything back apart except for an inner wheel bearing and seal.
And I'm not aware of any tool on the market for packing a tapered roller bearing while it's installed.
Spindle lubing tools, yes. Is that what you mean? Your spindles were bolted to knuckles already, and you're install the knuckles as a partial assembly? Not what it sounded like, but figured I'd ask.
If the wheel bearings are light of grease, that's an issue with the seller that needs to be addressed. You can only do so much by hand once the inner wheel bearing is in the cavity behind the seal. However, I would think you could make it work.
And then put a good amount of grease into the cavity from both sides. You don't need to pack that of course, but I've always used a pretty good amount of extra grease in there and liberally coated all surfaces and added extra.
So what am I missing? What was pre-installed and why can't you get to everything else besides the inner bearing?
L
Lon L
The spindle bearings and seals were already installed in the spindles , I have no clue if they were packed. I just was trying to avoid removing them since they were so well seated. I thought I had seen videos, showing a device that screwed on axle / spindle and forced the grease down the splines into the conical bearing.
The spindle bearings and seals were already installed in the spindles. I have no clue if they were packed.
Gotcha. They're usually not fully packed from the factory, but do not need a full packing necessarily either. However I do like to pack the bearings a little bit extra by finger.
Since they're there just inside the seal, a finger tip of grease is good enough. If you want to slobber a lot of extra grease just down into the spindle, that's not a bad idea either and when you install it on the axle shaft the excess grease will get pushed out the front. Where you can grab it and then pack in into the hub cavity or wheel bearings if they're not packed yet.
Since the spindle bearings are just caged rollers, with no real reservoir for grease, just what you can fit between the rollers is all that you need.
Yep, those buggers are really in there and you run a risk of buggering them up by removing them. You do not however need to remove them to grease. So that's a good thing.
Do your spindles have the large grease seal that's pressed in? Looks like a bearing seal?
Or do they have just the small seals that sit there behind the bearing? Since you say the seal and bearing are installed, I'm guessing you have the former. If you do, be sure that this is what you had before. If your Bronco is a later model and it had the floating seals then your axle shaft will likely not accommodate the large pressed-in seal and you'll have to remove it anyway.
Sort of. They do screw on to the spindle end, they do force grease down into it to pack the spindle bore and bearing. But there is no conical bearing in the spindle. Just what I described above.
The only conical type are the wheel bearings in the bearing hub. Spindle bearing is just roller pins and are only in use when in 4wd.
Spindle lubers are few and far between, but you can put grease in manually if you have the spindles still removed. Once they're installed on the knuckle and axle shaft, that's where the spindle luber is handy.
But not required.
L
Lon L
But not required.
Ah, gocha Thanks Paul. I will be installing the spindles , hubs calipers etc tomorrow... I hope :)
