Wheel size and back spacing question
Cloud9classics
Looking to go with different set of wheels on my 1970 Bronco. Going with American Racing Baja polished or Mickey Thompson Classic Bead Lock. I was planning on using 33x12.5.15 tires and wanted to get some expert advice on the correct wheel size and back spacing. Do I want 15x8 or 15x10? What is correct stock back spacing? Thanks for the help!!
Glass Pony
Sussex County Delaware
You will get some different opinions on BS and rim width.
I personally like the 8" wide rim. As far as back spacing no more than 3-3/4" (15" dia. rim) even then you might knock the wheel weights off.
I think the 76-77 disc brake axle is the one to really watch on the knuckles, the drum brake axle might have a little more clearance.
Here's a 33"x 12.5"-15" on an 8" wide M/T Classic Lock.
mritchy1
Mine are 15x10 Micky Tompson classic III with 3 5/8 back spacing and 33x12.5 bfg.I have no rubbing and they look great,
Crawdad
I have 15x6s and I believe they are 3" BS. Works great for me. Back in the day I had 35x12.50x15 with 3.5 BS and had no problem with the brakes but did rub the radius arms. I like the skinny look so 8s will look SICK!
