where / how did you run your EFI harness through the firewall?
Bronco_69
Monette Ar
I am ready to install the OEM 5.0 harness and need to find a good place to send it through the firewall.
PICs would be nice if you have them.
thanks
chris
fordtrucks4ever
DFW
It seems most everyone puts it thru the passanger side thats covered in detail on most EFI conversion sites. Try FFI and RJM or google early bronco efi. Tons of info that goes in to lengthy detail.
ransil
I have done a few like RJM suggests and 1 near the corner where the stock harness comes thru, not too many choices if you have a heater.
bax
Old Member
I ran mine on thru high on the center firewall just off center drivers side. Found a big rubber grommet and used it to protect the harness.
zeeman1
Seattle
I ran and mounted mine the same way it was on the truck I pulled it off of (93 F150)
kaknblz
Reno, Nv
I did mine like this also. Works great and removing that air box leaves the perfect spot for the computer. I used the mount from a 4.6 crown vic.
1sicbronconut
I did the LUBER a little diffrent than I usually do them. I have three of these flat ammo cans that fit perfect on the fender well. I've put the PCM and all the fuses/relays in the ammo can.
