Which 5 speed?
Bronco_46256
Elkhart
Yes, its trailpsycho' setup---it would have been easier for me to buy his old truck, since more and more of it morphs onto mine as time goes by.....
Its got 3.50 limited slip rear with 30x9.5 currently. I plan on going to 31s at some point. That all the tire I would ever use. I looked tonite on the highway and I was turning 2,000 RPM at 57 MPH. I was turning 2,000 RPM at 50 MPH with the 3 speed.
I just uploaded a few photos of the truck and the interor in the gallery.
B and M shifters make a shifter for the 3550 that I am seriously considering too. It says it tightens up the shifts and reduces throw by 30%. I haven't talked to anyone using this, but I bet it would make it even better.
One more observation, I read alot about trans noise on jeep sites. I have found very little except for when I go to first when I am still rolling. The synchros do a good job of catching up, but they really spool up fast and make some noise.
grauerfam
Owings Mills,MD
I think Stacey David used the B&M shifter on Crazy Horse. He cut the shifter handle off and welded on a Hurst handle - looks much better than the stock shifter. Alittle pricey, may have to wait on that one. As far as noise, I drove a couple Cherokees w/ the 3550 and did notice gear whine. Not bad, but noticable. Rented a Wrangler on the Outer Banks and did'nt hear any.
Bronco_46256
Elkhart
I cant imagine why you would. There's probably trucks out there running that right now.
Did my first higher RPM launch today at lunch and broke both tires loose at about a 2500 RPM launch. A Blast....
trailpsycho
No, you wont have any problems with the 3550 and 35"s as long as your geared properly for the 35"s. The 3550 is rated for 305 lb/ft of torque @ a a GVW of 7200 lbs. Even in a HD Bronco that approaches 5000 lbs, you would need close to 400 lb/ft of torque and lots of throttle and punishment to put it through some pain. I saw mine (now Chris') when it was being built; the counter shaft inside these things is huge and beefy...not very much different in diameter from the NV4500 and about 30-40% larger than an AX-15. They are a great choice for a manual upgrade from a stock 3 spd.
I decided I wanted a deeper 1st gear for off-road and a little taller OD since I was going deep on my axle gearing; otherwise, I would never have sold the one I had. I am still hoping that I dont regret it; it was great around town.... I only got to atke it on one moderate road trip (to Cleveland). I was a little too over-geared for the highway as I was running 31"s and 3.50s at the time (a 302 w 115K mi)...no problem normally, but I was towing and I couldnt really take advantage of the OD unless it was flat...18' trailer with windjammer ramps loaded with about 1/2 of a bronco will do that though...
I did run it all over the local interstates with great success, though. My speeedo was never correct b/c of the tire/gear discrepancy, but I could easily run in the 80+ mph without feeling like I was straining the engine...ultimately, I didnt have enough torque to go alot faster--faster due to the wind-drag of the boxy bronco (Ex: 31s, 3.50s, 3550 @ 2400 rpm I was running 81 mph) which is not where my engine made its best power....proper gearing and that wouldnt have been a problem....for example with 35"s, 4.56s, 3550 @ 2750 rpm you are running 80 mph....doesnt sound like a big difference-but it is- most of our motors are still just waking up at 27-2900 rpms or higher. By regearing and planning, I hope to be able to "do it all" with my next configuration...4.88s, 35"s, NV4500 and a good cam in a fresh roller motor. Best of luck with your decision.
John
DonsBolt
Chestnut Hill, Mass
That sounds awesome
I can't wait to put my NV 3550 in next week. I can break the rears loose, though it takes work, even with my crappy geared top loader. I can't wait to really smoke em now.
roundhouse
Potshot said:
Quick Question... I'm running 35s now, am I going to have problems with them when I do my 3550 swap?
I run 35's 4.11 and a 1990 EFI 5.0.
No problems with the trans, ( the D-20 and rear axle are worn out, but that happens when you use it for a DD for 11 years)
and mine is one that pops out of 1st gear, but I got it for $100.
