Which Fuel to Run?
EricLar80
Hey, I just put in a new 5.0 motor with an E303 roller cam, it is supposed to have 9.5:1 compression. I have it set to 10 degrees, which is what I think is a little above stock, it doesn't ping with cheap gas though. I was wondering if I should be running premium or the cheap stuff? Or is it just sort of a try it and see how it works thing? TIA.<br>-Eric
E
EricLar80
Oh yeah, it is fuel injected also, in case that makes a difference. <br>-Eric
76Broncofromhell
Bronco Totalitarian
Grass Valley, CA
I have an '89 5.0 Mustang with a new motor with the factory 9.0:1 compression and I run it on 87 octane and it seems to run fine. My Bronco on the other hand is a '69 4V 302 with 10:1 compression, and it will run ONLY on premium. The EFI engines are pretty adaptable so it will run on anything you put in it. If you can afford it, go premium.
Run the cheap stuff. for one it costs less, you can drive more. second, it is more powerful. That's right, more power out of cheap gas. How is this possible you may ask? here we go....<br><br>Cheap gas has more heat energy then high octane gas, gallon for gallon. Not much, just a few thousand extra BTUs more. It has a faster flame speed, this is why it wants to detonate if you run too much compression or too much advance. High octane gas has a slower flame speed compared to low octane gas under the same conditions. This is to control detonation. <br><br>Too much flame speed you risk detonation from the sudden rise in cylinder pressure. slower flame speed reduces detonation, but reduces cylinder pressure, which reduces power.<br><br>Most newer fuel injected engines have a knock sensor (the 5.0 is NOT one of them). With the knock sensor, running higher octane fuel will give more power since the computer will advance the timing to the limit of detonation.<br><br>The 5.0 (remember, no knock sensor) runs the same timing regardless if there is knock or not. Since you don't have detonation, you have a high enough octane rating. If run higher octane gas, then you will have a slower flame speed and less power with worse gas mileage.
Newt
Mustang 5.0's come from the factory with the timing set at about 10 deg. One of the favorite cheap hop up tricks is to bump the timing to 14 deg, some go as high as 18 deg. Remember to set the timing on a 5.0 you need to disconnect the spout connector. For this, you will need to run Premium fuel. But, it will give you a little better mpg to offset some of the cost.
E
EricLar80
[quote author=sicaz66 link=board=5;threadid=8728;start=0#62268 date=1031125748]<br>91 octane .just to be safe,<br>(BTW hey bro,you doin` LOS COYOTES in oct.?)<br>[/quote]<br><br>Yeah, I am planning on going so long as its not the same weekend as my cousins wedding. I've been driving my truck around a lot to try and break in the engine. So lets see here... Since last Coyotes run... new engine, new suspension, fuel injection. Yeah, I'm ready! ;D Are you gonna have yours up and running by then? No driving your wifes Exploder! Thanks for the relies guys, I think I will run premium for a little while with it slightly advanced once the engine is broken in, just to see how I like it. <br>-Eric
