2manynotime
Newbie
- Aug 9, 2019
- 24
I have a 302 out of a 2000 Ford Explorer and a Weiand 4 barrel aluminum intake manifold on it for use with my Fitech EFI. Anyone know what intake manifold gasket I should be using? I installed the manifold with the 1969 gaskets (Fel Pro) and I have a very small, slow coolant leak around the bolt closest to the thermostat housing. I see a very small trace of coolant there after I have driven it to work and back and then let it sit. I originally thought it was coming from the temp sensor in the manifold but after several times of careful checking, I am sure it is the bolt. I used thread sealant on the bolt when I originally installed it and followed the torque specs and sequence detailed for the 2000 explorer. The 2000 5.0 gasket looks similar to a 1969 302, but not identical so I'm not sure what to use.
