which locker to add?
Kyle.malone
Norman, OK
My project is finall ycomingto an end!! YAY!! I have completely stock axles and have a new ring and pinion for them waiting to go in. I know they did not have POSI or anyting else when bought. I believe they are both open diffs. 9" and D44. Which locker would you put in and why. I will have to havce someone put in the lockers and the gears as my brother in law doesn't have time to help out and I have no experience at all with internal axle parts. I don't think thsi is somehting I want to tackle myself. Thanks for your input.
I am open to may options and want the best for my rig. I will drive this thing more on the street with occasional offroading. probably about 90-10.
broncnaz
I'd probably just go with a rear locker 90% street no real need to be fully locked front and rear. my choice would probably be a tru trac which are very streetable. you'd be suprised at how far and rear locker will get you.
Actually the 9in is probably the easiest axle to work on so you could probably handle it yourself. All you need is a torque wrench dial indicator and a manual.
WyleCoyote
If you can afford it, look at ARB's. You get full streetability, with full lock-up when you want it. Maybe just a rear to save some money. Plus I agree with broncnaz, with a couple of tools and instructions you can do the 9" set-up.
needabronco
Prescott/Farmington
For a 90% street rig, I'd say either go with a limited slip, or an ARB. I have a Detroit locker in my rig, and drive mine fairly often on the street. Some people don't like the Detroit on the street, some don't mind them. If you plan to drive in snow or on ice, I'd stay away from them though. I'd also just do the rear end. You can always upgrade the front end later if you end up wheeling it harder.
TN1776
A rear Detroit will work wonders for you and is a little cheaper than the ARB. I do however have ARBs front and rear and love them on and off road. Being able to unlock is really nice but not a deal breaker either. Do you drive on icy or snowy roads often? If not, a rear detroit would probably serve you well.
And X3 on the ease of setting up a 9" carrier. If you have any mechanical ability and access to the correct tools you can handle it. I've built 3 of them now and can do them in a couple of hours.
mortimersnerd
I'll second what TN said. I'd personally go ARB, but I live in Colorado and like to freak out my neighbors by driving my doorless, topless truck around the neighborhood in subzero snow. I'd make fewer friends if my locker spun me into someone's living room. The other perk of the ARB is you'd have onboard air.
Green76
Sherman, Texas
I run tru tracs front and rear in my f150 and in the rear (so far) in my Bronc. I love em'. You never know they're there until you need them, no clutches to wear out, no special additives/fluids!
broncnaz
While a ARB is nice the cost, all the extra stuff needed and relatively little use would be one concern. The longer stuff sits under your hood unused or little used the more likely it is to fail when you actually want to use it. For the price of installing a complete ARB setup in the rear. You could easily lock both ends of the bronco with pretty much anything else and still have money left over. With no worry of a air line failing or $300 compressor taking a dump.
Kyle.malone
Kyle.malone
Norman, OK
I already have two Viair compressors that are 100% Duty and can fill my 8 gallon tank to 115 psi in about 3 minutes. I used them on my F250 to run air tools and such when towing. They came in handy being able to change a tire fairly quick and lift the trailer without too much effort. So I will probably look at the rear ARB since I already have some of the parts that will be needed. Thanks for the input and thanks for the link.. Going to go read it now.
NYLES
I like my tru trac and grizz locker if your gonna do a gear swap save yourself the headache and buy the whole third member for the rear by the time you by bearings and set up stuff you might even save money. On the front it aint to bad just alot of put it in measure and repeat till you get it right. Mines 95% street and OCBR I love it! Lil tire chip here and there makes it fun!
grimlock97
Wetumpka, Alabama
Definitely ARB, I had a 2k pathfinder with an ARB in the front and Rear, and a VIAIR compressor to engage and disengage, when locked it was a beast, and i could still drive it work every day, and the locker in the rear never engaged in a turn as i have seen some that do and then you are screeching all the way around. Just my opinion though, but a rear will be fine, my duramax has a rear locker and i don't need the 4x4 all that often b/c of it.
Kyle.malone
Kyle.malone
Norman, OK
After talking to 4wheelparts, I think I have decided not to go with the ARB. I am moer leaning towards a Detroit in the rear and a TruTrac up front. This way, I can get both axles taken care of for the price of hte ARB. Thanks for everyones help anf telling me about your rig!!
Opps.. I got them backwards. TrueTrac in the rear and the locker in the front.
WARD BRONCO
Walnut ridge
I run a grizzly locker in the rear and an aussie locker in the front, 250 bucks for the aussie locker and you can install it in about 2 hrs. I have several wheeling trips on the aussie locker and it works good. why waste the money for a l/S if the rears gonna be locked anyways. alot more bang for your buck. In my opinion.
Kyle.malone
Kyle.malone
Norman, OK
This just came to my mind.. I originally bought the "wide" gears for my gear swap a couple months back. Will they still work or will I need to get a standard size set?
OX1
If you will almost never use 4Wd on the street, I'd go front lunchbox locker and rear LS. That setup has almost zero affect on normal drivability and then it becomes a monster offroad (comparativley) with a front locker when the hubs are locked in.
This is the setup I put in my street bronc. Only wheeled it once in the snow (has 33" AP,s) and it did much better than I thought it would
KennyB
Simi Valley
I'm running 4.56:1 and 4.55:1 with Posi Front and Rear... It all came from Jeff's Bronco Graveyard... My Wrench looked All over the country, Got on JBG site, and picked Every Part needed.........
