Which lower rad hose solution?
jeffncs
Raleigh, NC
Truck is a 77, 5.0l with Explorer serpentine and a 1994 Explorer radiator.
Radiator is a nice clean install, inlet/outlet are each on the correct side and the top radiator hose from a Foxbody 5.0 fits perfectly…
The lower radiator hose is a 20” flexible, universal fit that’s leaning against the front crossmember. It’ll run but quickly rub through the hose. Any suggestions?
ntsqd
heratic car camper
Upper SoKA
Don't count on it rubbing thru the hose. Once had a rubber PS hose wear a hole thru a steel brake line. A little PSF and some grit was all that it took. Well, that and more than a couple of years. Hose had a flat-ish spot on it, but was still perfectly serviceable. AFAIK that truck was sold with that hose still in place.
Still, I'd want a better solution too.
tasker
all knowing of nothing
NH
tasker
NH
WILL SEE if i can find the numbers. Not my pics but identical to what I did
