5.0 explorer lower rad.hose
DEEPWOODS
Any one have any pics and a part# for lower radiator hose instead of crossover pipe used with explorer front dress conversion . I think some one came up with one that worked
6daze
I have some pics in my build thread (page5). I have a 2002 Ford F250 7.3 diesel hose.
Tito
CB Fire Starter
Bakersfield, CA
Are you running the stock in/out radiator? That would be great to know there is something that works without the crossover tube. Are you running electric fan or explorer fan?
DEEPWOODS
DEEPWOODS
explorer fan and water pump stock bronco in/out rad. I got a 2002 F250 7.3 lower hose # 62286 but no way I see it will work.I got the info from a older thread but I cant find it now
Call the parts store you got it from and ask them if there is an "alternate" hose for that application. We ran into that when doing a friend's conversion and there seemed to be no rhyme or reason to the different numbers (completely different hoses by the way) for the same engine/chassis application.
We assumed that there was some sort of optional equipment offered, or a mid-year change perhaps. It did not list it as a different engine though, just as an "alternate" part. And it was a definitely a much better fit.
Having said that, it didn't really fit perfectly either, so we ended up using the steel crossover after all.
Seems the one we got was still slightly different from Pedestrian's model, OR the setup in this Bronco was a little different from his. I'll see if I can get some pics in case it comes up again.
6daze
Stock radiator, Explorer fan, not perfect but it works.
