Which MSD Distibutor to get?
ZookBronc
South Orange County
I am running a late model 5.0 with a hydraulic roller cam, carburator, MSD 6a ignition box. And do i care if its a vacuum or mechanical advance? I have a vacuum advance now. I think it needs to have a steel gear on the distributor but which one do i get?
DonsBolt
Chestnut Hill, Mass
I wanted a vacuum advance on mine, so I run a 8479 MSD distributor with a 6AL box, and yes you will need to have a steel gear pressed on. If you are not in a huge rush call MSD as they will press on the gear for you for just a few bucks.
Then if anything ever happens, they can't ever say the gear was installed wrong
They also have
Ford 302/289 with Steel Gear for Hydraulic Rollers PN 8598
But that one has no Vacuum advance
Go with the vacuum advance. It helps part throttle power and economy. Only full race versions should go with strictly mechanical advance.
HPaddict
So Cal
i am running the Probillet as well. I dont know the part number off the top of my head, but can check when i get home from work if you like.
gjrock
Anacortes,WA
I am running the probillet.It was tall and the wires arced out on the hood brace.I had to cut the hood brake then rebrace it.I will check the part # tonight.
