The long F150 2wd inside mount box is a nightmare to set up. Drilling holes in the frame, messing with the radiator, etc. It is an old school conversion that hardly anyone does anymore due to the large number of better options out there. It will also only work if you have a suspension lift due to the length of the box. It is however, the cheapest way to get power steering due to the inexpensive box that you can find hundreds of at any decent junk yard.
The 4x4x2 is a much better choice but again, not an easy bolt on. Drilling holes in the frame or a conversion plate are necessary. Both of these create their own issues to deal with.
The simplest is finding an OEM power steering setup and simply bolting it on. The only difficulty here is figuring out the best way to modify the manual steering shaft, but you'd have to do that with any of the other conversions as well.
