Well, naturally they're shot so I need some that really fit well. So far my other experience with three other suppliers haven't been, well, just not good.
I replaced both my outer (just reapired the inner) rockers on my 74. Did them at seperate times. I ordered one from the Grave Yard and one from Wild Horses (it's a shipping thing I like to bundle).
Both were the OEM style and both fit with very very little modification. I had to grind/file a few spots and tweak some edges with a small body hammer to make it fit perfectly but it wasn't a big deal at all.
Be prepared to fine much more rust than you expect when you get the rockers off. I found very bad rust in the front area hidden by the rocker. Had to cut out weld in patch pannels as well as fab a few pannels. That took longer than the rocker replacement.
Oh, I used the cheap HF spot weld cutter to remove the old rockers. It worked GREAT.
