who has used new tailgate?
Casey835
Ive got one and was briefly tring to put the collapsible nuts in the holes for the handle assy. They dont work real well. What have yall used or done to accomplish this?
cldonley
Robinson, TX
Looking forward to this answer, I'm having the same issues. I was considering using captive nuts (aircraft style). You'd have to cut a slot to install them.
jcb9089
nutserts
I've had the same problem. The nutserts provided are cheap and easy to strip out.
I actually just did this on another tailgate and two out of 4 nutserts were ruined. I took a break from it, but need to fix as soon as I find good quality replacement nutserts.
meadowblaster
Same problem for me as well. I found some similar style pieces at the local Ace Hardware that were better quality. You have to buy a cheap install kit, but it works better than what the gate came with came with.
Casey835
Casey835
That sounds good, I just know that cheap crap that came with it ist gonna work.
regshawn
Portland
I just got lucky or maybe they changes quality of the years? I bought a new (still in the box) tailgate from a guy in Washington that bought it something like 10 years earlier. All but one of them worked perfect, the one works just a little loose.
Jeff76
Alpharetta GA
I'm having trouble with one that came from Tom's as well. When you say 'handle' are you referring to the latch assy on each end? That's where I'm having the problem...
Casey835
Casey835
No not the latch, the handle. Dont tell me theres problems there too!
cldonley
Robinson, TX
I only had trouble at the tailgate release handle. There are four nutserts for the four screws at the corners, that apparently everyone is having trouble with. Looks like you had a weldnut come loose...
Jeff76
Alpharetta GA
Two actually. Same one on either side. Problem is, there is a bolt threaded into the other one on the other side. and no way to access the backside. :-[
I will check on the nutserts for the handle as well. Thing is, this tailgate looks like a really nice piece, but these are pretty disappointing issues.
Jeff
cldonley
Robinson, TX
Only way to get that bolt in the broken weldnut out besides a hot wrench is a high-speed cut off wheel. If the bolt is still somewhat loose you pull the bolt out until the nut is tight against the metal and tack weld it. I've even super glued a nut in place a time or two to get a bolt out in those situations. The cut off wheel works best.
Jeff76
Alpharetta GA
With the recess where the latch goes (see pic), don't think a cut off wheel will fit. Also my partially installed latch is in the way as well... its a tough one, for sure, but that's part of fun of Broncos, right?
Casey835
Casey835
nutsert
This is how im tring to install the nutserts. It was what I understood the directions to say. It starts to colapse then it just start crapping up.
J-man
Holladay, UT
I ruined a few of the nuts when I put mine together. I ended up welding some nuts to the tailgate instead of the cheap fasteners they provided, works well holds up great and nobody know but me.
Zillacon
Hackin Away!
I can tell you one thing. After you install the nut zerts test fit the tailgate to make sure it fits and works before paint. I bought a Bronco that was filled with new sheetmetal and had a new tailgate from Duffs so I painted it to match my red bronco, assembled it and installed nut zerts and when they built the tailgate and spotwelded it together the handle area is offset about an 1/8" so the pin on the pass side will not pull in far enough because it is off center. Now I have to weld up the holes for the latch, re-center and repaint it one of these days to correct the issue or modify one of the rods going to the pin to make it a tad shorter to get the tailgate to work. Nutzerts work great. I am an HVAC guy so I have the proper tools to compress them. I use the ones that have a rubber o-ring gasket on them to help keep from spinning and marring the paint.
meadowblaster
I stopped by Ace after work last night where I bought mine a couple years ago, the don't have them anymore. You might check yours and see if they do though. They were in plastic trays by all of the nuts and bolts.
Good luck
